Hi YAM,
Make sure you don’t have both versions installed, otherwise they will conflict.
-Marcus
Hi YAM,
-Marcus
Thanks Marcus, it works great,
I was almost crying when the plugin run through
it would be great if this plugin has more function to rename all and rename all by folder name. for example I have 10 models in the folder named " metal " then when I press rename all the models in the folder " metal " the models will be named metal_01 … metal_10
hi marcus
Thanks a lot for the plugin!
Works great.
Cheers
giotto
From ZBrush 2022, SubTool Master has a “Rename” option which will add or remove a suffix or prefix from subtools.
But how to Rename with your plugin if I have random names and I want to change it? Like: Box_01, Sphere_02_Cone_01 ==> Tool_01, Tool_02, Tool_03
