That’s not a computer, it’s a space ship!!! (are you trying to make me feel worse? hahahaa)
and what about that video card? Not only for zbrush, but for “all” 3d programs, maya, lightwave etc…
zbrush is not dependent on a video card it uses ram for mostly everything except i think zmapper uses the video card.
Hi paufer, I don’t recommend you to have 2xvideo card to work, because the drivers are not optimized to work with 3d soft. In my case working on 3 screen with zbrush doesn’t make any problem, but with other soft like 3dsmax ( for exemple ) it crash evertime. So even a small video card work well with zbrush, but for others softs, prefer work with professionnail card fully compatible with OpenGL.
Good things !!
Wel, ok then… I don’t know if that video card is open gl. I’ll check it out!
thanks!
Guess I’ll throw in a pc config question in here!
The Pixologic site recommends a CPU with optional multithreading or hyperthreading capabilities… does the Intel Core 2 Duo support this? http://www.tigerdirect.ca/applications/searchtools/item-details.asp?EdpNo=3241546&body=MAIN#detailspecs
Hi sil, I have 3 pc, one with core 2 duo e6600, one other with quad core q6600, and a old pc with sempron 2800+.
With core 2 duo you can work perfectly even until 1000 millions of polygons.
Only make sure that you have at least 2 go ram for that. When you reach one million polygon the system need a lot more memory to be good. When I use quad core I detect more fluidity one work progress, ( it is more right when you use 3 screens like me and the memory video is use at his high possibility ). I can use zbrush when a dvd is playing on computer without any trace of blocking picture.
So core 2 duo is a good thing, but check it, often for the same price u can buy a q6600;)
And which windows is best for using zbrush ?
Will zbrush use more then 1,4 GB ram under Windows Vista 64bit ?
And did somebody use windows xp 64bit with zbrush? This would be my favorit.
Ok I bought it.
Its a quad core q6600
MB: Asus super hyper duper–> I forgot it’s name hehe
2GB RAMfor now
video car of 512 MB hd2600 XT
well, it’s almost flying here.
thank you all… and merry xmas and happy new year
