Odd taskbar problem...
My Taskbar is having a strange little problem. I have it set to do the collapsing thing, so it doesn’t take up extra space. I also have it set to “always on top”, so that I don’t have to minimize everything or press the keyboard Windows key to make it pop up. Normally this works fine, but for some reason the taskbar has decided to start not staying on top. The problem is intermitant, but does keep reocurring. Any suggestions?
Thanks. :slight_smile:
I’m sure you have already thought of this, but the only solution I can think of is: You have “always on top” set, but do you have “autohide taskbar” cleared? Not sure why both options are available, since they seem to contradict each other, but this can cause difficulties.
Actually I do want Autohide on. Auto hide is the opton that makes the Taskbar collapse so it doesn’t show unless you move your mouse to the bottom of the screen. Ordinarily the Always on top option keeps it there… on top. But now it isn’t. :qu: :qu:
