Hi all.
I had encountered this following problem and don’t know what steps I am missing:
I had created the following pistol as an individual file and it looks fine. However, when I saved it as a .ZTL file ( combined ) and tried to load this pistol ZTL file in another file ( to add it to a figure I am working on ), the surface of the pistol became rough and jagged. Also, when I first load it into another file, the loaded sub tool doesn’t appear even when I pressed the frame button. It’s only after pressing s.pivot that helps but the sub tool surface looks really bad. ( Please see attached images )
And same problem if I exported the model as obj and import into another file:-(
Thanks a million if someone can give me some pointers exactly what had gone wrong.
vince
