when i use move,scale or rotate tools, it deform my mesh,
what’s wrong? :eek:
here is a zscript also i recommend to read the transpose tutorial
http://www.zbrush.info/wiki/index.php/Transpose
while running the zscript will tell you to load an object load the demohead of Z3
Andreseloy
i tried to load your zscript and the text file by the load button in zscript menu,
than i click run nothing happen…
when you load the zscript at the left down corner apper a buttom called Play
Andreseloy
i tested it before send !
look by yourself,in the first image, i see transpose strech,but it’s noy what i want…
after the move, the result…
It looks like you have part of your mesh masked. Hit “clear” in the making section of the tool menu. Transpose tools will only affect unmaksed mesh portions.
Click in the center circle to move uniformly.
thanks 'a lot bingo jackson,
it was a mask problem, i cleared the mask and the transpose tool work well now…
thank’s you too Andreseloy for your help,
i appreciated…
call me nuts…but I kinda like your accidental results there.
