GM,
Naming is a tricky issue.
Actually, I was leaning towards asking to append MERGED at the end so if the file is saved with that name to a folder, it could be found close to other saved versions with related names… however, since the filename derives from which ever subtool is active at the time it is saved, that doesn’t make much sense. So, maybe, if it is applied at the beginning, it could then alphabetically mingle with other merged tools saved to disk at other times.
In the QuickSave plugin, because of the auto-incrementing of the same filename, I always scoot up to the top of the list to subtool 0 and increment that (then scoot back down to which ever was the active subtool before the save.)
Looking forward to the next version!
Sven
