In the Essentials tutorial about using the Edit button, the narrator talks about and demonstrates rotating, moving and scaling. When you hit the Edit button you can rotate your object by just moving the mouse with the left button pressed. If you hold the Alt key and move the mouse, you can move the object. But then the guy says “and you can scale” and he has not pressed the scale button. What is the keyboard combination that he is using to scale in the Edit mode.
And where in the Help could I find this answer. I couldn’t find it.
Thanks for your help.
Katherine
