Help on "mirror" morph target for Poser figures
If I make the left side (let´s say a collar)in (ZBrush of course) and export it as an oobj file, what can I do to make a copy for the right side? (Inside ZBrush)I was told
how, by a guy somewhere else but that did not
work out. (I probaly have done something terribly wrong :slight_smile:
Please help!
Z
'Afternoon Zrincx . . . :slight_smile:
It’s fairly simple: When your finished editing & painting your object / deselect “edit object = T” / select “move = W” / click on “Snapshot Object = Shift + S” / select “Tool / Modifiers / Deformation / Mirror = X” / now you can move the Mirror object over to the desired position / all you have to do now is either Save or Export the Mirrored object. :wink:
I hope this helps you some, & you have a good one . . . :cool: Mark.
[img]http://www2.zbrushcentral.com/zbc_uploads/user_image-1002419555xrr.jpg[/img]
It worked! Only problem is that it obviously
is impossible to mirror a part and then think
it fits on the other side of a Poser figure!
At least the outcome is heavily deformed and
looks no way like the opposite side. That is
a Poser problem, not ZBrush( I think).
Thanks anyway for your help :slight_smile:
Z.
hmmm, i’ve messed with poser only once but a few veryvery good tips re: interaction zbrush/poser are included in Auricks great PoserEnhancer ZScript.
hope this helps!
  • juandel
