Help me PLS!!
Hello to all zBrusher!!
I have a problem:
“Why when i render the image it appears out of focus??? I wrong in some settings??” or depend from the material used???
(P.S. My english, day by day, are always not good!!! :smiley: :smiley: :smiley: Sorry!!!)
Check the antialiasing settings in the render panel, Mr. B, and then post them here…Maybe then we can see what is happening… :slight_smile:
Tnx Stone !! I try soon !!! :smiley: :+1: :+1:
Tnx for the advice Stonecutter!!!
I have changed the setting into reder panel:
:b2: _____________________________
In this image have Blur=100 and Edge=100
In this image have Blur=0 and Edge=0
Have a little difference but HAVE !!! :smiley: :smiley: :smiley:
P.S. The options SUPER SAMPLES=1,2,3,4 what means???
TNX
Nice Mr. B… :+1:
I use Blur at 20, Edge at 17, Sample size at 3, and SuperSample at 2…
Now I believe someone with more technical knowledge should answer the question about Sampling, since I would probably only confuse you… :smiley:
I think you have it working for you now though! :wink: :+1: :+1: :+1:
Tnx Stonecutter!!
I dont find the Sample Size options!! I have only the 1.23b demo version!!!
Is a new option of 1.5??? :smiley: :smiley:
EDITED_________________________________
SORRY STONECUTTER !!! I HAVE FOUND !!! :smiley: :smiley: :smiley:
EDITED 2°______________________________
If i know this setting my image of zORC for 3d passion Contest are more clear and defined !!!
:rolleyes: :rolleyes:
TNX again zFriend !!! :smiley: :smiley:
:smiley: , McBraun!
Glad you found it, and good luck in the 3D Passion contest…Maybe you’ll have 1.5 soon!! :+1: :+1: :+1:
EDIT: That is a GREAT image Mr. B! Those yellow teeth are amazing and work so well with the skin tone! You should see if you can replace the previous version…Write the guy running the contest to see if you can do it…
Tnx Stonecutter !!!
I try … :smiley: :smiley: :smiley: :smiley: :smiley: … but is equal… is a game !!
:smiley: :+1:
