Colour picker making colours too dark
Ah sorry, my mistake, I thought I had to press it after starting up the program. That did it! Thank you so much, this really helps me out!
Great, now I think we have a solution. If you encounter the problem then make sure you press the button and then save the project. That way eventually you will get rid of it.
What was the main issue? This is something I’m currently running into now. I haven’t been able to figure out what the issue is though. How did you fix it? The link above is no longer accessible or the script as well. Any help would be wonderful. Thanks, everyone!
hi @Menty,
It might happen when you have a masked area on your mesh.
hope it helps!
Nicolas
Hi Menty,
The problem was because the RGB Intensity was set to less than 100 when Edit is OFF. This means the model is partially transparent and so the picked colors are not full intensity.
You can correct it by setting the Texture palette Image Plane>Reference Views>Model Opacity slider to less than 100, then resetting to 100. (You need to do this so that the model updates properly.)
And here is the original macro:
Reset RGB.txt (371 Bytes)
HTH,
Marcus
Thank you!!! I’ll give it a try!
