Thanks for the tutorial man.very nice and beatifull.i m amazed why this is not on the top bar yet.please put it there.
Great tutorial…
Top row…
Thanks for the comments guys! I’m happy people are making use of the tutorial.
I would hope to see some more work posted here on ZBC using this method for rendering in ZBrush.
I know this is an old thread:(
Could someone explain this part a little more in depth/how to?
With all the elements in place, I started working on the lights. I wanted the scene well lit so I created 7 total lights and rendered them individually as separate passes which I then composited together in Photoshop. I used “Screen” mode mainly for each layer and adjusted the intensity for each layer with the layer transparency slider. Also, doing it this way you can selectively erase the lighting from one of those layers if you like it on one part of the scene, but not the other. Once all the lighting layers were added and adjusted to my liking, it looked like the image labeled “Layers Composited”. After the layers were flattened, I adjusted the levels for color intensity and saturation.
Hi thanks for sharing this. Beautiful image and a very informative breakdown!
