Okay, sorry for the other hand. I guess Zspheres from 1.55b are not 100% compatible with Z2. I checked it out here at home, and you were right, the fingers are all messed up!
Anyway, here is a new zscript, that works fine in Z2. Here is how the hand should look once the zscript is finished.
Also, you will need to reset your document size to 1024 X 768 or 1280 X 1024. Then, when you hit the play button, DO NOT initialize Zbrush. I started this tutorial with my default settings, and I forgot about the 640 X 480 default startup document.
If you have your show actions on, you will see that I adjust the zsphere density settings when I make the zsphere at the palm of the hand. It goes by quickly, so here is what I did.
After you make the palm zsphere, switch the density sliders back to 0.
Here is the new and improved zscript. I hope this one works for everyone.
Right click and save as
