093536 091973 091042 090818 090781 090617More Highlights
Register FAQ Search Today's Posts Mark Forums Read
Reply
Thread Tools Search this Thread Display Modes
Old 01-09-06 Reply     Quote     UserGallery     ThreadGallery     Post#121
spaz8
Senior Member
The Mac version of Zmapper is still in the works right?
Just making sure it hasn't be released without me knowing.
I just dont see the download links to the PC or Mac version at the beginning of the thread.
spaz8 is offline
Old 01-09-06 Reply     Quote     UserGallery     ThreadGallery     Post#122
abe_Tamazir
Senior Member
I've tryed to transfer a bumpmap+highdef sureface on another geometry but it doesn't work....Can we do that with the zmapper or does the bump transfer works only on the same geometry ?
thanx for any help
abe_Tamazir is offline
Old 01-09-06 Reply     Quote     UserGallery     ThreadGallery     Post#123
ryankingslien
Senior Member
spaz8 - yes.
abe_Tamazir - Currently, in ZMapper, you can not use the bump transfer method with an arbitrary mesh (different model).
Ryan
ryankingslien is offline
Old 01-11-06 Reply     Quote     UserGallery     ThreadGallery     Post#124
Mojoke
New Member
Hi I noticed that Zmapper currently limits the poly count to 500,000. Is there a way to increase this? If not, will this limit be increased in version 2.5? It's kind of a bummer to have to go one level down and lose detail. Please let me know. Thank you.
-M
Mojoke is offline
Old 01-11-06 Reply     Quote     UserGallery     ThreadGallery     Post#125
Scott Spencer
Senior Member
you can always make a displacement map of that level, apply it as a bump and bake it into the normal map.
S
Scott Spencer is offline
Old 01-11-06 Reply     Quote     UserGallery     ThreadGallery     Post#126
Mojoke
New Member
I've notice some noise whenever I bake out displacement map...But that's a great idea to try since I don't have any alternatives right now... Thank you for your help!
-M
Mojoke is offline
Old 01-11-06 Reply     Quote     UserGallery     ThreadGallery     Post#127
ryankingslien
Senior Member
Mojoke - can you describe your workflow? ZMapper will read all your higher levels of resolution. You do not need to go to the highest level when you enter ZMapper. Not even for Projecting Normal Maps. Are you using scan data or... ?
Cheers,
ryan
Old 01-12-06 Reply     Quote     UserGallery     ThreadGallery     Post#128
abe_Tamazir
Senior Member
thanx for the info ryankingslien...hope this fonction will be added for tthe next update aith the color / heightmap baking and transfer...
i dont understand the problem too Mojoke...you shouldn't need to worry about the poly count of the model you use as you just need the level 1?
Old 01-12-06 Reply     Quote     UserGallery     ThreadGallery     Post#129
Gareee
Senior Member
Can the normal mapping be converted into uv mapping?
Since the point locations are the same, maybe the normal mapping can be converted into uv mapping.
(For instance, in lightwave and poser, you can apply the normal displacement maps onto the uv mapping.)
I just don't understand if you already have a good non distorting uv map, why you would want to remap the normal map as well.
Gareee is offline
Old 01-12-06 Reply     Quote     UserGallery     ThreadGallery     Post#130
Mojoke
New Member
Hi thanks for replying. My work flow as follows:
I created my hi-detail zbrush tool. But later, I had to make geometry, topology, and UV layout changes. I was using zmapper to generate a new normal map from the new base mesh (level 1 sdiv) with all the changes and my old hi-res zbrush tool.
My initial concern was that each time zmapper would ask me to reduce my sdiv level one down and so I thought it wouldn't be getting all the juicy details at the highest sdiv level. But I think you're right in that it kept all my juicy details from the highest sdiv level.
-M
Mojoke is offline
Old 01-13-06 Reply     Quote     UserGallery     ThreadGallery     Post#131
abe_Tamazir
Senior Member
that's actually the purpose of Zmapper....getting the highrez detail onto the lowrez....
Old 01-15-06 Reply     Quote     UserGallery     ThreadGallery     Post#132
craigs
Member
Default model offset out of display area in zmapper
when i hide the body of my character, just to have the head displayed, and bring it into zmapper, it is there when i orbit around with the rotate tool, and move it into the center of the screen, my question is, is there away where when before i bring it into zmapper, i can ensure its orientated, and going to be position in the center of zmapper.
I tried center pivot in the work area of zbrush, and local pivot so it was in the center of my head but neither has worked.
Any help appreciated.
craigs is offline
Old 01-16-06 Reply     Quote     UserGallery     ThreadGallery     Post#133
abe_Tamazir
Senior Member
you can load and draw a star tool, then just import your model and it will replace the start concerving its location....
Old 01-22-06 Reply     Quote     UserGallery     ThreadGallery     Post#134
tuddel
Member
The model i made was high res but i for the small details i used a bump map.Is it possible to use the bump map for making the cavity map?
tuddel is offline
Old 01-23-06 Reply     Quote     UserGallery     ThreadGallery     Post#135
ryankingslien
Senior Member
tuddel - if you roll your bump map into your normal map it will also work for making cavity maps. See section 2.2 in the documentation which you can get here. Instead of pressing Create Normal Map press Create Cavity Map.
Ryan.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
