moonlitmaverick: Thanks, I like your creature and render from post #95.
nice work !!! thanks for the cavity mat cap
Excellent renders and sculpting. Impressive !!!
RenoAnimations: No worries.
michalis: Thanks man.
Skin maps
Great clay look !!
Great Work
How do you make your images so huge? I'm trying to do that
Thank You
Shalabum34: Its under the document menu. Set the size you want(its in pixels) then double it for both height and width. Once the Doc size is twice the size you want press the AAHalf button on the right side of your document. This way only works if you are exporting document. If just using the BPR and exporting from there make the document the actual size you need. I think theres some tutorials on this site if you use the search function.
clay material
great material, could you maybe post this clay matcap?
if not thanks for posting your renders
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
