That's how it works.Originally Posted by Cral
This little plugin is for entering slider values without using the keyboard. It's a ZBrush 4 version of one originally posted in this thread.
Installation
Unzip the file and put the Numpad4.zsc in your ZStartup/ZPlugs folder. Restart ZBrush and there will be a new Numpad menu in the ZPlugin palette, with a single Numpad button.
You need to assign a hotkey to the Numpad button. Ctrl+Alt+click on the button and then press the hotkey you want to use. Store the hotkey by pressing Preferences>Hotkeys>Store.
Instructions
Hold your cursor over a slider and press the hotkey. The interface will appear and you can enter a value by pressing the buttons. Press the = button (or Enter on the keyboard) to enter the value into the slider.
The mannequins are made by inserting polymeshes into a ZSphere structure. You can also use this technique to create chains and similar structures which can be edited and posed (as Joseph Drust shows here).
This plugin makes inserting the meshes easy, with two meshes being used, one for the local mesh that replaces the ZSpheres and one for the connecting spheres. (Individual meshes can be replaced by hand afterwards if you wish.)
Unzip the file and put the ZSphereMeshInsert.zsc file and ZSphereMeshInsertData folder in the ZStartup/ZPlugs. After restarting ZBrush there will be an Add Mesh to ZSphere button in the Zplugin>Marcus Tools menu.
With your ZSphere selected, press the button. You will be asked to select two meshes from disk, one for the local mesh and one for the connector mesh. The plugin will then create a new structure with the meshes inserted.
The zip includes two chain link ZTLs which can be used to make a chain.
In the tutorial mentioned, one can choose to do either 'local' or 'connector' but the plugin forces the use of both at the same time.
Is there a way I can use only 'local'?
Basically when I follow the plugin messages, my chain link sizes are not consistent even though my zspheres are all the the same size.
brandonlawless.com
lawless 2011
lawless 2010
Corsair GRAPHITE 600t, i7 2600k 3.4GHz, Win 7 Pro
16GB RAM, n580GTX lightning extreme ed
27 inch iMac, 3.4 GHz Intel Core i7, OS X Lion
Brandon,
I've updated the plugin so that if you only choose a local or connector mesh then the operation will go ahead with just that - simply cancel the open file dialog for the one you want to omit.
Marcus,
When I hit preview, two chains are created. One is a bit offset from the other.
Another program (Modo) has this: you create the chain links, then you duplicate along a curve. Maya and other programs have this as well. Don't worry to much if this is proving difficult.
I mean - chains are awesome and I think many people would love them. If you can create a way that works, great. The tutorial on the Zbrush wiki has opened a can of worms. After seeing it, trying it, and after your work on this plugin to make that tutorial actually 'work', after all of this, I'm not sure the method is better/faster than using Modo or other programs.
Thanks for the effort though.
-B
brandonlawless.com
lawless 2011
lawless 2010
This is a beta version of Turntable Plus for ZBrush 4 which I am posting here because some people have found it useful. This will export an image sequence for BPR renders.
For installation, follow the general instructions here:
http://docs.pixologic.com/user-guide...inInstallation
Note that this is simply a first pass and there will no doubt be issues and some things may not work as expected. It does not work with the Timeline.
Instructions:
The plugin works in the same way as before except for some new switches for BPR.
* Turn on the Turntable Plus>Best Preview Render switch to use BPR
* You then need to set the little switches to export the different maps
* After pressing the Render Movie button you'll get the options dialog. Note that if you are using BPR then the HDGeometry, Image, Alpha & Depth options will be ignored - you need to set these options either through the Img, Dep & Msk switches in the Turntable Plus menu or in the case of HDGeometry, the option in the Render palette.
* After the options dialog you'll be asked to save the first file for each of the different image exports. Note that what Turntable Plus calls an 'Alpha' is the BPR 'Mask'.
* For other BPR Render options, set the options in the Render palette.
Download ZBrush 4R3 version here: TurntablePlus_4R3.zip
Download ZBrush 4R2 version here: TurntablePlus_4R2_01beta.zip
Download ZBrush 4 version here
I created my own import and export buttons that automatically flip the UV's of .obj's when they are imported/exported.
I found it really tedious always having to vertically flip my textures and also things like "tool > UV > Morph UV" are a just waaay cooler when your UV's are oriented correctly.
Ideally I think this should be an incorporated option into the "Preferences Importexport options" There are already a lot of options for flipping textures but not UVs, seems kind odd to me. My scripting knowledge isn't great enough to have this be a toggle button that would run automatically like the rest of those buttons though.. =/
***Anyway, these scripts are meant to be used together as they only Flip the UVs so that your UVs and textures are not upside down in zbrush. ***
Instructions:
simply extract all of the contents from each .zip into your Zstartup/Zplugs folder and then in zbrush under Zplugin you will see a “E” panel – where each of these plug-ins reside.
import_flip_uv_v.zsc
This script opens the import .obj dialogue box and then automatically flips the .obj's UV’s Vertically for viewing of textures and UV’s correctly inside of zbrush.
export_flip_uv_v.zsc
This script automatically flips the selected tools UV's vertically then opens the export dialogue box, then flips the tools UVs back again after export. This script is used in conjunction with "import_flip_UV_V" script. If you don't flip your UV's back before exporting than your UV's will be flipped in whatever other application you are viewing your .obj in.
Thanks a lot --E-- !
@ --E--:
I also always flip the UV coordinates after import or before export (Tool -> UV Map -> Flip V) instead of flipping all the maps/textures to address the problem by the root and not just treat the symptoms.
But I really don't understand why ZBrush creates/uses UV coordinates in this unusual manner at all!?
And I would actually vote for changing (fixing!) this offbeat behaviour in the next version of ZBrush.
SorinLupu - Glad you can use it
Phönix - Yes a global fix would be ideal. Or at the very least have it be a set option that you can turn on and always have it on every time you start zbrush like the other "Preferences > ImportExport" options. There are already a ton of options for always flipping your model upon import and export but nothing for flipping UV's.![]()
This little plugin gives fixed Y rotation in increments set using the slider.
Unzip to the ZStartup/ZPlugs. Restart ZBrush and there will be a new submenu called Y Axis Rotation in the Transform palette.
Set the Rot Incr slider to the increment you want, as part of a 360 degree turn. So for 45 degrees set the slider to 8. Then press the Rotate button and a model in Edit mode will be rotated by the increment.
There are a couple of issues - the canvas needs to be set at Actual Size. And sometimes the model will flip upside down - this tends to happen when the increments are exactly on 90 degrees so starting just a fraction off the full face on can solve it.
Download Here
[For an any axis version of this plugin see here.]
This macro will initialize ZBrush and then load the Startup Document if there is one.
Simply put the file in your ZBrush 4.0\ZStartup\Macros\Misc folder and then press the Macro>Reload all Macros button or restart ZBrush. There'll be a new button called 'Init_ZBrush' in the Macros>Misc menu.
this not work for me.Originally Posted by chan1234
it show this error to me.
Sometimes you might want to do something to all subtools and would find it useful to have a macro for future use. This example shows how it can be done if you are prepared to edit a macro in a text editor like NotePad.
First of all record a macro of the action you want to apply but just do it with one subtool. Make sure you select the subtool before starting recording the macro and don't select any other subtool before ending the recording. Save the macro to your macros folder, select a new subtool and test it, to see that the macro does what you want.
Next you'll need to open the macro file in a text editor. You'll find it in the ZStartup/Macros folder (or a subfolder of that). Open it up and you'll see code something like that below. The Gray code is the start and end of the macro; leave that as it is. The bit you need to copy is between the [IConfig,4.0] and the last bracket ']'.
Next open the Do All SubTools macro attached to this post. You'll find the Do It routine towards the top. Paste the code from your macro in the middle of the routine:Code://ZBRUSH MACRO - Recorded in ZBrush version 4.0 [IButton,???,"Press to run this macro. Macros can be aborted by pressing the ‘esc’ key.", [IShowActions,0] [IConfig,4.0] //Copy all the code here and put it in the DoIt routine in the attached macro. ]//end of macro button
When you're done editing, save the file to the ZStartup/Macros/Misc subfolder and press 'Reload All Macros' or restart ZBrush. The macro should then work on any number of subtools.Code:[RoutineDef,DoIt, //put code here ]//end of routine
The attached example macro All Subdiv 3 will set all subtools to subdivision 3 (if possible).
See here for a Visible SubTools Macro.
