1. #46
    Senior Member Follow User Gallery
    Join Date
    Aug 2009
    Location
    Shelby, OH
    Posts
    195
    Default
    cubanb82: I'm afraid I have to agree with you, that it really doesn't fit the character. I still want it to look a lot more advanced than the traditional predator, but I think I was going about it the wrong way. I think I should try to give it a more segmented/ ornate feel. As it is, the pieces of the armor are a little too big and solid, and I think it's looking a little too much like master chief. that's my theory anyway.
    I think I'll keep the design, and maybe just use it on a Colonial Marine instead.
    www.tristanflor.com
    --Available For Hire--
  2. #47
    Join Date
    Aug 2009
    Location
    Shelby, OH
    Posts
    195
    Default
    Here's another update. I have, more or less, completely reworked the concept. I still tried to get full-body coverage with the armor, but this time I think I was able to do it in a way that looks more like something a predator would wear.
    I also wanted to take the time to mention my standard-brush settings that I use to get hard lines for panels, and other hard surface elements...
    In the Brush pallet go down to the curve menu and adjust the curve so that it makes a sharp point on the right side. Then, enable the 'accucurve' option, which is also found in the curve menu. This option forces the brush to adhere to your curve settings exactly, where as normally you may not see much (if any) difference. This produces an effect similar to the 'Damien-Standard' brush, but it produces the effect without pinching.
    I thought I'd mention it, because it took me a long time to realize, and as much as I loved the 'Damien Standard' brush, the pinching that it used to get the same effect, eventually got in the way.
    www.tristanflor.com
  3. #48
    User Gallery
    Join Date
    Jan 2005
    Location
    South Africa
    Posts
    1,032
    Default
    Looking good ...now you gotta start refining those surfaces
  4. #49
    New Member Follow User Gallery
    Join Date
    Jan 2010
    Location
    cali
    Posts
    16
    Default
    looks great dude,personally i liked the first predator suit you made better,simpler looking,sure it was not a traditional predator look,but original and a new way u could go with it (story wise) anyway great work
    madness as you know it's like gravity... all it takes is a little...push
  5. #50
    Default
    It's intriguing to see a predator this way as opposed to the usual ET rastafarian tribal warrior get up. Makes sense that the predator species would also need essential military gear to repel existential threats....very cool progress, will be watching!
  6. #51
    Join Date
    Mar 2009
    Location
    within US borders
    Posts
    549
    Default
    It's the head and the mask. It just grabs me. I like it.
    "Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius — and a lot of courage to move in the opposite direction." -E.F. Schumacher
  7. #52
    Join Date
    Aug 2009
    Location
    Shelby, OH
    Posts
    195
    Default
    Hey All,
    This is kind of an intermediate update. I haven't started doing any detailing yet, but there's been a lul since I last posted and I wanted to get the thread moving again.
    I started a new concept. One which will allow me to get into detailing the predator anatomy. This guy is going to be one of the older 'elite' predators, who has lived for so long, and become so intune with his body, that he can go into battle with minimal armor, and weapons. He also deprives himself of the camouflage generator, and wristblades.
    I have started detailing his face and mask to reflect past battle damage. Instead of getting a new mask, or having the old one completely repaired; he will have incorporated into it's design, the strike that took his eye.
    I've named him "Stone Heart" after the predator alpha from 'Predator: Concrete Jungle'. I've always really liked that name.
    (I added the spikey little hairs on his face by using the 'mesh insert' brush)
    www.tristanflor.com
  8. #53
    Join Date
    May 2009
    Location
    Antwerp, Belgium
    Age
    33
    Posts
    87
    Default
    This is coming along great Keep 'em coming!
  9. #54
    Join Date
    Jul 2010
    Location
    Chicago, IL
    Age
    38
    Posts
    50
    Default
    Yea, this is really looking beautiful! Or ugly as the case may be The little hairs / spikes on the face now are perfect! Really add to it. Can't wait to see the armor details!
  10. #55
    Join Date
    Aug 2009
    Location
    Shelby, OH
    Posts
    195
    Default
    Hey All,
    Another Update. Not a whole lot farther along. I mostly just worked on fine tuning the body, adjusting the anatomy and such (mostly the legs and hands), and adding the little bumps and skin texture that they have.
    I also made the fishnet suit. It's an actual mesh and took a long time to do, which brings me to my REQUEST FOR HELP. If anyone can think of a way to do this a little bit faster I would DIE to hear it. The way I ended up doing it was by retopologizing the torso in the fishnet pattern, then bringing it into maya, beveling ALL the edges, deleting all of the in-between faces, and then extruding it all.
    I don't want to sculpt it on the body because i want it to be visibly separate, as if you were actually looking at a predator costume. I don't want to do it with an opacity map, because I want it to be visible in Zbrush, and I want it to have depth.
    The way I originally did it worked pretty well, and would be fine if I was going to just constantly use the standard diamond shape; but I eventually planned on making more elaborate fishnet designs, that would signify more advanced cloaking device. And, trying to retopologize the torso using any sort of elaborate pattern would take forever.
    I have 3DS Max 2010, Maya 2010, and Softimage 2010. Any suggestions would be appreciated.
    www.tristanflor.com
  11. #56
    Join Date
    Jun 2010
    Posts
    21
    Default
    Incredible! Only critique I have is that there is something a bit off in the lower shoulder area. Looks like either the brachialis is too high or there is a new muscle I have never seen before If it is the posterior deltoid, it needs to be pushed back and blended slightly.
  12. #57
    Join Date
    Jul 2010
    Location
    Chicago, IL
    Age
    38
    Posts
    50
    Default
    @TheNameless .......really dude?
  13. #58
    Join Date
    Aug 2009
    Location
    Shelby, OH
    Posts
    195
    Default
    It is indeed a new muscle... but an accidental one.
    My knowledge of muscle groups, and placement, is pretty vague. In order to sculpt anatomy I look at a combination of muscle diagrams, photographs, and zbrush renders. Because I'm never sure exactly where, or how many, muscles there are I often end up getting mixed messages from the different pics, leading to stray or altogether new muscles. As near as I can tell what youre pointing out is where the brachialis and deltoid meet. I think I got confused and over emphasised their connection, which led to a new muscle.
    Glad people like you can point out my goofs. Otherwise I don't think I'd ever notice them.
    www.tristanflor.com
  14. #59
    Join Date
    Jul 2010
    Location
    Chicago, IL
    Age
    38
    Posts
    50
    Default
    But.....it's a Predator!
  15. #60
    Join Date
    Oct 2008
    Location
    Sao Paulo - Brazil
    Posts
    485
    Default
    aahha!! it´s comming!! really great model!
Page 4 of 10 FirstFirst 1234567 ... LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
