I am not a huge fan on how far zbrush 3.5r3 scales in on the model when the “f” key is pressed.
Hi Eric,
If you temporarily increase the canvas zoom the mesh will be fitted to that. After resetting the zoom you should get the size you want. This is the idea:
[IButton,Fit,"Fit mesh to view",
[IFreeze,
[VarSet,tmpZoom,[CanvasZoomGet]]
[CanvasZoomSet,tmpZoom*1.1]
[IPress,Transform:Fit]
[CanvasZoomSet,tmpZoom]
As you’ll know, the [IFreeze is to hide the process from the user. You could add a slider to provide the value that the canvas is enlarged if you wanted.
HTH,
This is different way which makes use of the transform values of the object - essentially the same as your original macro but using zscript commands.
[ISlider,"Fit Value",0.9,.01,0.1,1.5
,"Set value for mesh fit",,,1]
[IButton,FitMesh,"Fit mesh to view",
[IFreeze,
[VarSet,fVal,[IGet,zscript:Fit Value]]
[TransformGet,xPos,yPos,zPos,
xScale,yScale,zScale,xRotate,yRotate,zRotate]
[TransformSet,xPos,yPos,zPos,
xScale*fVal,yScale*fVal,zScale*fVal,xRotate,yRotate,zRotate]
]//end freeze
]//end button
Hey Marcus,
But I am afraid I am running into a snag trying to put this into the UI so that I can assign a hotkey to it.
[ISubPalette, "Zplugin:TEST"]
[ISlider,"Zplugin:TEST:frame_value",0.9,.01,0.1,1.5
[IButton,"Zplugin:TEST:frame",FitMesh,
[IFreeze,
xScale*fVal,yScale*fVal,zScale*fVal,xRotate,yRotat e,zRotate]
]//end freeze
]//end button
nm!
I think I got it sorted out.
Here is the code I am now using if anyone else wants it
[ISubPalette, "Zplugin:Frame_mesh"]
[ISlider,"Zplugin:Frame_mesh:Frame Value",0.9,.01,0.1,1.5
[IButton,"Zplugin:Frame_mesh:Frame Mesh",FitMesh,
[IFreeze,
[VarSet,fVal,[IGet,Zplugin:Frame_mesh:Frame Value]]
]//end freeze
]//end button
THANKS AGAIN MARCUS!small_orange_diamondsmall_orange_diamond
That’s perfect Eric, I’m glad you got it sorted.
One further thing that could be added is a check for Edit mode. This would ensure that the resizing only occurred to a model, rather than 2.5D brush strokes.
Just wrap this code around the [IFreeze block:
[If,(([IsEnabled,Transform:Edit]) && ([IGet,Transform:Edit] != 0)),
//other code here
]//end if
Cheers,
Thanks again Marcus, you are such a huge help here on ZBC!
I played around with your two different code samples a bit on several of my tools and I found the first code sample to be a lot more stable. Even after I added the last bit of code you gave me.
I am not sure if it is something I am doing wrong or what, but the code sample with the slider appears to crash zbrush for me and also frame some of my models oddly when they are partially hidden.
Anyway, I tweaked the first code sample to scale out a bit more with a “1.2” value instead of “1.1” and it appears to be working great so far!
[IFreeze,
[CanvasZoomSet,tmpZoom*1.2]
I am extremely happy with this script! Big thanks to you Marcus!
Cheers!
Would it be possible to make such script to zoom in the zone under the cursor ?
That would make a perfect “scale detail mode”…
