nice weapon on your weapons man, great sword designs!
Jaysus, could you possibly explain number 7 of your workflow( baking textures onto the duplicate )? I have been looking at tutorials as you suggested but sadly I'm still a little lost
not sure which worflow you mean atm... sorry lol, its late XD
but i guess we just created an awesome thing in high poly and now need a low poly version for realtime/game use?
if so then you need to transfer the detail of your high polygon count model to the lower resolution version of it somehow, project all for example in the subtool palette works quite well for that,
however you might not need that if your new low poly uses the very same uv map... which could be the case if your high poly has one because it was made out of your low poly... then you could just bake the textures and apply them... your model however woulndt end up with as many detail as with a new low poly based on the high poly,
whatever you do lol, keep in mind that project all can take ages and not always does it work well... usually it does tho...
there are sooo many ways... it really just depends on your workflow...
for most of these swords i had a uv mapped low poly version made in max already, like the last sword, i made a simple dragon head in ZB, retopoed in 3DCoat, adjusted in max, uvmapped it, exported back to ZB, detailed it all...
thats not always a good workflow, especially not if you create your design on the fly on ZB not knowing where it will go... if you know how your endproduct shall look however, creating the low poly first as described above might be better
always looking for all kinds of work in the field of design, art and creation
Portofolio
aggravating me?
lol no no...
@baking
ZB does that for you
if you have a uv mapped low poly, add subD levels and sculpt the detail you can immediately bake all kinds of maps from your high poly model onto the low poly model's uv map texture space thing
which maps you need depends on your design and material
but you always need to bake the polypainting aka colour aka diffuse and the normal or bump map... the specular can often, or most of the time actually, quickly be created in photoshop or gimp by simply adding contrast and reducing saturation...
mind that for skyrim and other bethesda games past morrowind need the specular or your object will be shining bright...
Portofolio
doodeling here and there on the shark...
Portofolio
nice work JaySus on your shark creature!
the silhouette is great man
just doodled around once again and made a really dirty easy portrait of a musician friend of mine for whom i sometimes make record covers and such,
its simply an alpha of a photo i took, smoothed out a little... no sculpting or any of that sophisticated stuff :P
yet i think it looks kinda sexy
Portofolio
mmh... ill repost that link XD, i think it kinda got lost underneath that picture :/ ...poor linky
ZB layer/shapekey test
i am currently toying around with "Realflow", a fluid, particle, physiques thingy tool whislt working on that logo i did for a buddy... all still very experimental and rendering or rather simulating takes ages, but it gives a bit more flexibility than the ZBrush timeline features, which however are awesome for what they are actually supposed to do lol, got some nice basic animations down with ZB, spinning and getting closer with nice material variations, kinda stylized, ill ask if i can show some of
the stuff below are just some test runs:
ZBrush animation (emerge from the deep)
RealFlow/Max animation (bleed and explode)
Portofolio
short logo video test for another project im working on, the request was "something with blood" (lol)
Malefiz-Haus Logo Test
the letter models were done in C4D and provided but the geometry was horrible and had to be redone by me, since 3DMax's turbosmooth was not the right tool this is where ZB came in, i used the smooth group import and subD levels to smooth my low poly model out... its probably not something that sounds very reasonable but in this case it was imo the fastest solution to get good looking geometry
am still learning realflow atm and this render video obviously isnt in the best quality, cheap scanline renderer resulting in weird shadows and so on...
Portofolio
a secon test run of that logo with a tad more blood
Malefiz-Haus Logo Test 2
Portofolio
Posting Permissions
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
