1. #31
    Default
    Couple more pieces -
  2. #32
    Default
    really nice work. great to see some environments here for a change.
    was just wondering what percentage of gears 2 env was done using zbrush?
  3. #33
    Default
    Thanks for all the comments folks.
    Workflow -
    I don't do anything fancy really, I do however do a lot more front-end planning than you might expect. I always work on the grid, even the bricks are on the grid with centered pivot points so I can reinstance them back in max to create variants and ensure heights between bsp tiling textures and static meshs that share the same bricks match up ingame.
    Really, I'm a big planner, thats all I do thats different.
    I spline most of the basics of the design, shell it then when I know its all working on the grid like interchangeable lego bricks and will be capable of supporting multiple meshs I move on to equally subdividing each section.
    Part of my planning here takes the form of thinking ahead with the design as to how to split up the large blocks into smaller elements so that they are easily manageable in Zbrush in subtool chunks that dont individually exceed about 2million polys (4 million tris) so that there is less polygrouping on the back end required to get all those pieces back out of zbrush into max to batch polycrunch and then use blues importer to bring them all into max and process along with the non zbrushed elements.
    I work very simply in zbrush, I try to immitate how a stone mason or a carpenter might work, just pummeling away and scooping the forms out of the blocks with mallet fast and clay brush initially before relying on the other tools to refine once I'm done with the bold stuff.
    I use alphas a lot, some of them rendered through height maps and gradient renders of forms I liked in max so I can stamp the deco on to things in zbrush and create more natural and worn looks. Other times I just export the modelled deco pieces and damage them in zbrush, sometimes I generate alphas in zbrush with grabalpha, edit with Crazybump for small details and cracks.
    I use lazy mouse a lot and radial symmetry tricks but mostly I just bang on stuff with the clay brush until it looks right, I control everything through thinking ahead , planning it out, subtools and polygroups because I'm kind of anal retentive now.
    Plus, as amazing a tool as zbrush is, its not got a grid system that I trust like max has so I tend to do more on the front end in max than most of you would think is necessary. I do this because I want to be sure of reuseability as often we have to work quite fast here and zbrush is as much of a help in that for me as reuseability in max is.
    The steel plates are all instances rotated around the pivot point of the arch.
    Everything that is original or damaged was blocked out in max on the grid and then the detail and designy stuff was weathered in zbrush.
    The Snakes were modelled straight and plain in max, pretty much just smoothed cylinders until I detailed them out in zbrush, then when I exported them back I could unwrap them straight, before I then path deformed them into location. This is again, another symptom of my always trying to plan things out more on the front end so I get more use of things on the back end and can make the resolution higher ingame.
  4. #34
    Senior Member Follow User Gallery
    Join Date
    Apr 2006
    Location
    Iowa, USA
    Posts
    280
    Default
    thanks for sharing your work flow.. your images are stunningly clear,clean, and visually pleasing.... the twisting pair of serpents are considered by some to be the two subtle nerves that twist along the spine and that are awakened by deep meditation... and form the basis for celestial perception, spiritual awakening and freedom from limitations.. re:Ida, Pingala and Sushumna
  5. #35
    Default
    Vedanta:
    Thanks, I hadn't heard of that one about that one, I'll need to google those names, they sound indian, I like the indian mythology, its one of the closest surviving relatives to the beliefs of the celtic mythology that I'm most interested in.
    Have you ever read Alan Moore's Promethea series of comic books? Theres some great stuff in this vein in there, she wields a caduceus sure, but its more a story about the nature of inspiration and the true meaning of magic and its use in interpreting the world around us in terms of symbolism.
  6. #36
    New Member Follow User Gallery
    Join Date
    Sep 2006
    Posts
    12
    Default Awesome !
    Wow Kevin this is awesome ! Great stuff i just got a question theres a lot of tutorials abour zbrush with characters but i having seen alot on enviroment any body knows where i can find some?
    THANKS a again awesome Stuff
  7. #37
    Join Date
    Jul 2007
    Location
    Suffolk
    Age
    38
    Posts
    304
    Default
    Great work and thanks for your insight Kevin, you sound very organized and certainly ahead of the game ; )
    _________________________________________________
    I N F I N I T E
  8. #38
    raziel31
    Guest User Gallery
    Default
    Very interesting, thanx for the tips
  9. #39
    Join Date
    Jul 2005
    Location
    France
    Posts
    19
    Default
    You guys have done a great job on GoW 1&2, you have done some impressive pieces of work. And thx for sharing your workflow. Can we hope of a wip in pictures? (or best in vid, looooove vid tutorials ).
    Blog (FR)
    Sketchbook (FR, Café Salé forum)
    Zbrush Sketchbook (ZbrushCentral)
  10. #40
    Join Date
    Aug 2007
    Location
    Auckland, NZ
    Posts
    344
    Default
    Ok, now I´m gonna have to play this game even more, just so I can tell everyone "i know who did it".
    Very nice use of zbrush..
    Fábio Paiva - Character Artist
    Artstation
    Facebook
    fabioppaiva@gmail.com
    Available for remote and contract work
  11. #41
    Join Date
    Oct 2008
    Location
    Germany
    Age
    31
    Posts
    2,406
    Default
    Congratulations for the top-row. These pieces are terrific! I love the snakes.
    I´m way impressed.
    And many thanks for sharing your workflow.
  12. #42
    Join Date
    Apr 2004
    Location
    PA
    Posts
    28
    Default
    Those pillars rock! really awesome! Well it all look fantastic! anyway you could show us the process you go through with a few, wip pics? Thanks!
  13. #43
    Join Date
    Jun 2006
    Location
    Bangalore, India
    Posts
    192
    Default
    fantastic! awesome detailing!
  14. #44
    Join Date
    Apr 2006
    Location
    Atlanta
    Posts
    506
    Default
    Congratulations on the top row.
    Well deserved!
    markkens
  15. #45
    Join Date
    Jan 2009
    Posts
    331
    Default
    This is really inspiring work! Amazing, really!
    It will be pleasure to wach how you make such assets ?! If you have the time and desire, some day, it will be nice to make a movie "the making of"
    Wish you best man!
Page 3 of 11 FirstFirst 123456 ... LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
