1. #136
    Senior Member Follow User Gallery
    Join Date
    May 2005
    Location
    Iceland
    Posts
    188
    Default
    Wel I'm sure we're all looking forward to that - impressive thread you got going here - thanks for sharing
  2. #137
    Default tiled work
    Hi Kevin
    WOW - great work love it so much.
    1 question how do you get ztools to line up just right like
    http://www.zbrushcentral.com/attachm...hmentid=134756
    I tried so many times but using ~ but they never line up?
    If anyone here know - let me know
  3. #138
    Join Date
    May 2007
    Location
    San Diego
    Posts
    1,413
    Default
    maxmax20093d he talked about his use of the grid in Max to make modular elements earlier in this thread. Read and all shall be revealed.
  4. #139
    New Member Follow User Gallery
    Join Date
    Apr 2006
    Posts
    1
    Default
    Do you still have those brushes, I would LOVE to get a look at those
  5. #140
    Join Date
    Sep 2008
    Location
    Burbank, CA
    Posts
    68
    Default
    Agreed, I'd love to take a look at some of those brushes btw! I can't believe I missed this thread - fantastic resource to say the least.
  6. #141
    Default
    So aye.... kind of promised to show these a while ago. Sorry for the delay!
    I mostly just made some tribal shapes in max to start with, rendered height maps, edited a little in photoshop and then relied on lazy mouse with the standard brush in Zbrush to trail forms like in the upper right , or the leafy ones at the bottom left, across the main forms.
    Then I'd just follow through on top of that noise with the clay tools and mallet fast, pinch, standard brushes to more boldly define the forms that stood out most to me. I tend to work this way a lot, throw big bold forms in, roughly throw a string of medium patterns on top and then pick out the happy accidents by hand and refine them.
  7. #142
    Join Date
    Dec 2007
    Location
    Seattle
    Age
    42
    Posts
    319
    Default
    Nice! Thanks for sharing.
  8. #143
    Join Date
    Jul 2008
    Posts
    28
    Default
    WOW***65292;it's awesome!Thanks for sharing***65281;
  9. #144
    Default videos
    Hi Kevin Johnstone
    Are you going to make any videos @ http://kevinjohnstone.com/
    I would love to see how you use your tools, Zbrush and so on
  10. #145
    Join Date
    Mar 2009
    Age
    29
    Posts
    509
    Default
    This gets a bump for other people to see just because of how helpful you are at explaining your workflow. Everyone should see it.
  11. #146
    Join Date
    Aug 2005
    Posts
    19
    Default
    Hey Kevin I have noticed that when I render height maps out of Max I get quite a bit of grain. Do you get this as well and if not, what do you do to counter it?
    Nice work!
  12. #147
    Default
    Love the Gate,
    you can feel the weight of it.
  13. #148
    Join Date
    Feb 2010
    Location
    Bend, Oregon
    Age
    49
    Posts
    87
    Default Quick question reguarding your brick work...
    After making the bricks in max, touching them up in Z brush, decimating them, and importing them back into max, how are you getting the ends to tile? And how are you capping what you crop in max? I understand how to make the tileable textur ein Z, but I dont understand how you got it in max.tile.jpg
    Brian Pape
    www.jbpape.com
  14. #149
    Join Date
    Jul 2003
    Location
    Tampa, Florida
    Posts
    1,590
    Default
    Amazing work and thanks for taking time to share so much info with us.
    Dustin
    .:|Sketch Book |:.
  15. #150
    Default
    Thanks for the comments.
    Bipolar : Thats just a presentation thing I did for our artmeetings, I just made a copy of the side bricks and sliced in the middle and then split them neatly apart so I could convey that the scene I was showing translates into a tiling texture.
    I try to be clear in what I am presenting, if I showed my 'processing' version of the scene with the bricks having jaggy outlines where the tiling seam is, it might look like a pretty useless model.
    So I generally present what we call BSP models ( because when processed they are textures that are meant to tile along a BSP wall of the level designers choosing) in tidy squares like this.
    As I mention though, when I process I make sure there are instances of the bricks extended a further 32 units outward from the area that I process my normal maps from. Sometimes I bang the bricks up too much in zbrush and reduce or enlarge their scale too much, so if I create extra at the edges of the process area I am ensuring I capture precisely how those bricks continue to repeat at the edge of the texture.
    Not doing this sometimes results in seams where the repeat points are. If you made tiling 2d textures in photoshop on the last generation of tech, you know how invaluable the OFFSET filter there was to make sure the tile is correct at the seams, this is just the 3d version of that workflow.
    rayo777: I don't worry about that, I work messy and nothing I do is just imprinted and left raw, I always merge, overlap , combine, add and subtract from what I imprint with alpha stamps.
    I think, honestly, if I could generate perfect 1 stop alpha stamp designs, once I imprinted them on the mesh, I would feel kind of nervous to touch them more, sometimes imperfection pushes me to be more confident about trying to improve it.
    maxmax20093d: I don't know, I do know that actually getting more than a front page up will come first
Page 10 of 11 FirstFirst ... 7891011 LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
