1. #301
    Senior Member User Gallery
    Join Date
    Mar 2006
    Location
    germany
    Posts
    362
    Default
    those last pieces are really very nice!
    Especially the one piece is very inspiring to me.
    Keep it up,J.
  2. #302
    Join Date
    Mar 2007
    Location
    Seattle, WA
    Posts
    236
    Default
    jmeyer,Intervain,hmphhh,Moni-Poroni - thanks for the kind words and positive feed back
    carver- thanks and he damn well better or he gets a poke to the eye.
    saeedm - I use modo for my block up, zbrush to sculpt. matrix to do my stone work sizing and sweeps. I use decimation master to reduce the pieces to import into matrix or 3d export to go to magics.
    all of the programs have there uses and strengths.
    if you need any other info feel free to contact me about it....
    t
  3. #303
    Default advice
    your very inspiring..
    im new to zbrush and i just sculpted this skull and i was wondering how i would go about making the ring hole..? in zbrush or export it to another program.
    im not sure if zbrush has the precision like rhino where you can make a 19mm radius circle, extrude it, then dif boolean. etc etc..
    all the help is truly appreciated.. ;]
    Attached Thumbnails Attached Thumbnails Click image for larger version.
Name:	three quarter view signature skull.jpg
  4. #304
    Join Date
    Mar 2007
    Location
    Seattle, WA
    Posts
    236
    Default
    I would export it as a STL and do the boolean in magics. or export it as an obj and boolean it in rhino.
    I build my block up with a hole in it, in modo.
    if that didn't help feel free to keep asking until I do
    t
  5. #305
    Join Date
    Jan 2005
    Location
    South Africa
    Posts
    941
    Default
    really cool stuff - awesome actually
  6. #306
    Join Date
    Mar 2007
    Location
    Seattle, WA
    Posts
    236
    Default
    thank you very much,
    there should be some new work soon
    t
  7. #307
    Senior Member
    User Gallery
    Join Date
    Jun 2006
    Location
    Walvis Bay - Namibia - Africa
    Age
    53
    Posts
    589
    Default Gr8
    Great as usual... one day when I grow up, I also want to do work like this....
  8. #308
    Join Date
    Mar 2007
    Location
    Seattle, WA
    Posts
    236
    Default
    aaaahhhhh my friend have higher aspirations than that lol
    t
  9. #309
    New Member User Gallery
    Join Date
    Aug 2010
    Location
    girona
    Posts
    24
    Question What 3dprint do you use?
    Amazing..What 3dprint do you use for this high quality results?
    Thx and congratulations...!
    www.3dtecnics.com - art for a new World!
  10. #310
    Join Date
    Mar 2007
    Location
    Seattle, WA
    Posts
    236
    Default
    the last pieces were grown on a DWS or digital wax machine.
    I can find out the exact model if you like but I think they paid in the $150,000 range for it and in turn the results.
    t
  11. #311
    Default
    hi T.S.,
    when you build your block up and boolean out the ring hole in modo, do you do this at a low level geometry then import it into zbrush, then start dividing for more geometry??
    im having a tough time importing my model into zbrush from rhino and being able to finish it do to this problem..
    your help is very much appreciated.
  12. #312
    Senior Member
    User Gallery
    Join Date
    Jan 2005
    Location
    NJ, USA
    Posts
    297
    Default
    Beautiful work, as always.
  13. #313
    Join Date
    Mar 2007
    Location
    Seattle, WA
    Posts
    236
    Default
    jmenna - thank you....
    solidsilver - hmmm I don't boolean in modo for the hole and I never wind up with that kind of seaming problems..... did that come from Modo?
    ok that sounded crappy thats not how I meant it....
    I mean i have no idea how you got that geometry out of modo.
    if that is from rhino you have to set the weld settings in the import sub-tab
    I can show you what i do in modo if you like, there is no need to boolean.
    but thats an import issue common in matrix/rhino
  14. #314
    Default
    T.S.
    thanks for the weld tip ! i will give that a shot.
    if you could show me how you do it, that would be a huge help.
    Basically i do everything in zbrush but when its time size the piece & cut the ring hole i use rhino, ( i dont have matrix ). but if i need to import back into zbrush for some more detail and adjustments i cant do to this current issue. :{
  15. #315
    Join Date
    Mar 2007
    Location
    Seattle, WA
    Posts
    236
    Default
    yes...
    thats a hell of a transition rhino doesn't make good geometry for zbrush.
    all you do is instead of using the normal import button use the one in the tools menu and have weld turned on. give that a shot...
    bu i would just suggest to use rhino last ]
    t
Page 21 of 31 FirstFirst ... 121819202122232430 ... LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
