1. #76
    New Member User Gallery
    Join Date
    Jul 2010
    Posts
    1
    Default
    Can this method of making bump maps be applied in zbrush 4.0?
    And if so, what kind of displacement generation settings do you guys suggest one should use?
  2. #77
    Senior Member User Gallery
    Join Date
    Jul 2002
    Location
    USA
    Posts
    1,174
    Default
    I'm also curious about this in ZB4.
    sadicus ~ Vista x64 • nVidia GeForce 9800 GT • ZB4 •
    ...you do doodle, I do doodle too.
  3. #78
    Join Date
    Oct 2010
    Posts
    4
    Thumbs up
    Amazing !!!
    well done Rastaman...
    Thanks to shear your helpfully trick....
    but Is it possible work in creating Normal Map?
    I've try follow your step and try make normal map in same way, but I'm not find any change for Normal Map and Texture map, only for displacement map its work...
    is it possible to create special Normal and Texture Map, as your way to make Displacement map that really work ???
  4. #79
    Join Date
    Jun 2011
    Posts
    2
    Default a guess
    That's a greyscale texture map--from polypaint, e.g., or at least it looks like it. Oddly enough I usually just double up the TM as Bump whenever I can. You got good results, too,... definitely. Awesome , man ... thumbs up.. I always feel like I'm jerrry rigging when I get it into maya, especially when it's all pro-ish as far as maps and such... Hell, I've really never even known for sure if a bump is a cavity map or some other thing. Could look it up i guess. But, I'm a 3d noob--3 months and going--trying to make a shoestring feature film look huge, with a schizo bum giving an inaugural speech to the world--even though no one but the cameras and chairs show up at capitol hill... Gotta lotta work... Tricks like this make stuff easier...
    Cheers.
  5. #80
    Join Date
    Sep 2003
    Age
    33
    Posts
    140
    Default
    is this morphing required, can;t we just go to lowest subdiv level ?
  6. #81
    Join Date
    Mar 2005
    Posts
    596
    Default
    Is there some reason why the youtube video was removed?
  7. #82
    Join Date
    Feb 2009
    Posts
    19
    Default
    The information in this thread was erroneous and unhelpful, hence it's deletion.
    If a moderator is around, they would be wise to delete it!
  8. #83
    Join Date
    Dec 2004
    Location
    Germany
    Posts
    513
    Default
    tristamus
    What is your problem ?
    The described way and the generated special maps worked great so far for me and some others.
    If you don't like it, simply do something else. That's your choice.
    Please avoid further comments like this.
    Rasta's -Tutorials can be found hereD
    Link-thread to all tutorials:
    http://www.zbrushcentral.com/showthread.php?p=673344
  9. #84
    Join Date
    Sep 2010
    Posts
    396
    Default
    Quote Originally Posted by tristamus View Post
    You mean a thread that's 3 years old?
    Instead of just flat out saying it's erroneous why don't you provide some insight and updates to the information? It would be helpful for those looking for this information later on.
Page 6 of 6 FirstFirst ... 3456
Posting Permissions
  • You may not post replies
  • You may not edit your posts
