Hi,marco problem(solved)
I recorded a marco, but when running marco ,there have been some error messages - only loaded 8 material, I would try to load it manual, there is no problem for the last two materials, I would try to replace a lot of material, none of them can be loaded normally, why?
This is a marco.
//ZBRUSH MACRO - Recorded in ZBrush version 3.1
[IButton,???,“Press to Switch Model UI.”,
[IShowActions,0]
[IConfig,3.1]
[FileNameSetNext,“ZBRUSH_\ZStartup\HotKeys\ModelingHotkeys.TXT”]
[IPress,Preferences:Hotkeys:Load]
[IPress,Material:Noise2]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RS_GreyClayLight.ZMT”]
[IPress,Material:Load]
[IPress,Material:GradientSky]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\Orangeclay.ZMT”]
[IPress,Material:GradientMap]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RS_CooperLight.ZMT”]
[IPress,Material:GradientMap2]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RS_GreyClayExtreme.ZMT”]
[IPress,Material:GradientIntensity]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RS_MBShader.ZMT”]
[IPress,Material:NoiseBump]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RS_ResinBlueEdge.ZMT”]
[IPress,Material:Intensity Reflect]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\xBlinn_complex.ZMT”]
[IPress,Material:GradientMap3]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\xMudbox.ZMT”]
[FileNameSetNext,“ZBRUSH_\ZStartup\Macros\UI Switch\Modeling Interface Wip8.cfg”]
[IPress,Preferences:Config:Load Ui]
[IPress,Material:FastShader2]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RSRS_WinstonClay.ZMT”]
[IPress,Material:Colorizer2]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RS_RS_GreyClay.ZMT”]
[IUnPress,Menus]
Tnanks for your help!!
I think the most likely problem is that the files are not named correctly. Are you sure all those material files are in the folder?
i found,
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RSRS_WinstonClay .ZMT”]
[FileNameSetNext,“ZBRUSH_\ZStartup\Materials\sculpt\RS_RS_GreyClay.Z MT”]
I have some careless.These two letters should be deleted:o
thank you ,marcus_civis :+1: :+1: :+1:
