1. #16
    Senior Member User Gallery
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default
    Here is the progress of my scene. I FIIINNNNNALLLY managed to get some decent displacement maps for the house out of and into XSI. I also have the door, hinges and handle all displaced, door has a normal map on it, which if i get time i will change to a disp map, maybe depending if it is needed. All colour maps painted in ZB, and imported to XSI. scene with one spot (moon) and one point light in the room on ceiling. Plan on adding curtains, glass window, and maybe flowers in a vase, along with monsters of course
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  2. #17
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default
  3. #18
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default
    For some reason the image doesnt upload into the main msg window :S oh well, have to place as thumbnails. here it is
  4. #19
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default
    Here is my scared monster all detailed up and the start of the colouring
  5. #20
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default
    I have been having some render problems in xsi with mental ray, for some reason the maps and sizes and the subds seem to continually make xsi crash at render. I managed to get in a low res render which i will post tonight. I still have some work to do, mosnter with mask, vase and curtains, but im hoping it will get done tonight
  6. #21
    Join Date
    Feb 2002
    Location
    ohio, U.S.A
    Posts
    1,194
    Default
    Hey Micheal glad to see you are getting things accomplished! Your scene is looking good, but I think the color of the floor and wall should be different. They currently make the room look as if it's constructed from one material. Also try adjusting how the texture is tiled. The tiles on the floor might look better if near the wall they were full sized. (thats if your using a tileable texture) If not just move the floor plane a little past the wall. Sorry to here about your rendering woes, I had to switch to Zb 2.0 to do my Zsphere modeling due to crashes. I try to check in often tonight to see how things are going.
  7. #22
    Member User Gallery
    Join Date
    Oct 2007
    Age
    32
    Posts
    31
    Default
    that is nice he look good
  8. #23
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default
    Hey thanks guys, for the floor i actually started a new scene, placed a plane and subdivided a few times, then i painted tiles on with the tileablitliy repeat function then drew on using a square alpha with drag rec brush. i then saved the alpha of doc(mrgbgrab i think) then used stencils and painted on the floor the tiles. The whole room is one object, so floor, window, walls and ceiling are one. it was hard getting it how i wanted from xsi, as i wasnt sure of how or even if zbrush could do it. and i think doing it as a whole was better for painting.
    you say a dif colour for wallas/floor? any ideas? in the render i will post tonight it looks a little different, it all sort of looks like clay/mud, but ideas would be good.
    as for the monster, he is finished now with texture map, nails/claws, cavity map, and eyes, tho i will retouch the eyes in zb when the final image is complete.
    Thanks
  9. #24
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default
    Oh also, with the tiles, it being one object, it will be hard for me to alter that now its done, (i think) i just had an idea, and if i get time i will try it out. i just thought i didnt want it to look so "neat" and "human" as its a monsters house, if you get me :S
  10. #25
    Join Date
    Feb 2002
    Location
    ohio, U.S.A
    Posts
    1,194
    Default a question.
    Hey Michael, I'm not really certain about your work flow. Was the last scene image you posted a Zbrush render? I was kinda assuming you were doing the final render in XSI.
    Edit: looking back, you did render that in XSI...So I'm guessing you have one UV map for the interior of the house?
  11. #26
    Join Date
    Feb 2002
    Location
    ohio, U.S.A
    Posts
    1,194
    Default
    And another thought, just a lighter color for the floor, or walls... just break it up a little...and use your lights!
  12. #27
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default
    Hey Brian, hehe yeh twas rendered in xsi, . you guessed right, only the one texture map for the interior, i will go back and change the floor and wall colouring, ive been thinking of a light blueish for the wall.
    Here is my scene with low res house. high res monster and door etc
  13. #28
    Senior Member
    User Gallery
    Join Date
    Dec 2006
    Location
    Sydney - Australia
    Age
    35
    Posts
    691
    Default
    your last scene looks nice ... good luck
    There is no failure, except in no longer trying.
    CG Society Portfolio
  14. #29
    Join Date
    Mar 2007
    Location
    Sydney, Australia
    Age
    29
    Posts
    103
    Default Scared Silly Entry by Michael Docking
    Well here is my final render for my entry. Comments/crit welcome
    Thanks for the cool contest. I had fun and learnt a whole lot both of Zbrush and XSI. Look forward to the next one.
  15. #30
    Join Date
    Sep 2007
    Location
    Leicester, UK
    Age
    33
    Posts
    1,453
    Default
    This is a nice effort XSI, there are many who started this comp and never even got close to finishing. you should pat your self on the back for finishing in good time.
    Id be tempted to make a couple more concept drawings next time around and then try your best to stick to the one you chose. The trouble with this scene is that it is difficult to see what's actually happening. the monster on the floor looks like he is scared and the moster at the window looks like he wants to get in for some reason... but that's it. Maybe a trick or treat bucket on the vamp would cure the whole story?
    Don't get me wrong, your use of 2.5D tools is admirable and your modeling skills are good. you just need to try stick to one concept as you go along and only change if the story is lost in the scene.
    Well done for finishing. you have the potential to become a great 3D artist and this effort just proves it. Keep it up!
Page 2 of 3 FirstFirst 123 LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
