1. #1
    New Member User Gallery
    Join Date
    May 2003
    Posts
    8
    Question Import/Export problems with 3D Max 5.1
    Hi everybody,
    My first question in this (very nice) forum is perhaps a very basic one:
    I finished modelling and texturing something in ZBrush, let's say a head.
    Now I export the head mesh with dxf. No problem here.
    And I export the texture-map (created with TextureMaster). Works fine, too.
    Now I start up Max 5.1 and and import the head-mesh. I open the material editor and create a new material with the imported bitmap.
    And there it happens: after applying the material to the mesh I don't know how to adjust the uv-coordinates-stuff so it looks like it did in ZBrush. The texture is alwasys twisted or streched or just not fitting.
    Is there any work around this problem?
    Many thanks in advance,
    Stefan
  2. #2
    Senior Member User Gallery
    Join Date
    Dec 2001
    Location
    Frederick, Co. U.S.A.
    Posts
    1,146
    Post
    Stefan,
    I would suggest exporting your model out of Zbrush as an .obj file as opposed to .dxf. The .dxf files do not use uvmaps at all.
    This should fix your problem.
    Take care,
    Michael
    "I am still Learning"
    By: Michelangelo
  3. #3
    Join Date
    May 2003
    Posts
    8
    Post
    Hi Michael,
    thanks for your reply. However - it sounds stupid - but I am not sure if 3D Max can import .obj files. I tried to, but it says: wrong import-data.
    Is there a plugin for Max or do you know anything else regarding this issue?
    Thanks again
  4. #4
    Join Date
    May 2001
    Location
    vancouver
    Posts
    3,693
    Post
    yes there is, obj2max plugin doesnt work in version 5.1 so with the recent help of my z buddys i was able to find this site with the answer.. http://www.3d-station.com/ressource/impexp.php
    its about the 4th one donw from the top, and its called alias wavefront importer, dont worry about the site because its in french because youll download a english version plugin.
  5. #5
    Join Date
    May 2003
    Posts
    8
    Post
    Hi Dr. jjwow,
    IT WORKS GREAT!!!!!! THANK YOU VERY MUCH.
    Are you just a little longer in the forum right now?
    I am going to play a little bit with it, and i am sure there will be another question...
  6. #6
    Join Date
    May 2001
    Location
    vancouver
    Posts
    3,693
    Post
    your in the right place for help either here or somewhere else.. post your questions and im sure many people will help you.. if you want my help directly you could email me at mazap1@msn.com.
  7. #7
    Join Date
    May 2003
    Posts
    8
    Post
    Hi again,
    this realy is a great place for help.
    I am just working on with the TextureMaster Rhinoceros - Tutorial. At the end, they apply a shiny orange belt around it. It has a very high specular level.
    Of couse, when exporting the texture/material to .psd or .bmp this shininess is lost.
    I think there is no way to tell 3D Max that this portion of the texture is shiny and the rest isn't.
    Am I right?
  8. #8
    Join Date
    May 2001
    Location
    vancouver
    Posts
    3,693
    Post
    im going to say no it doesnt because the material and shaders differ from zbrush or rhino.if im wrong somebody here will set it straight for you.
  9. #9
    Join Date
    Sep 2001
    Location
    Austin, Texas
    Posts
    1,351
    Post
    Right, there is no way in the native output from ZB for Max to know that a certain area should have a certain material property, such as specularity or reflectivity.
    However, I am assuming that there is a way to use bitmaps in Max to control things like specularity, reflectivity, or displacement. So, you could either edit the ZB texture in PS, converting it to grayscales and isolating the areas that should be shiny and use that as a specular map, or you could re-texture the rhino in ZB using grayscales and output that as your specular map.
    Jay
    "Talent and all that for the most part is nothing but hogwash. Any schoolboy with a little aptitude might very well draw better than I perhaps; but what he most often lacks is the tough yearning for realization, the teeth-grinding obstinacy and saying: even though I know I'm not capable of it, I'm still going to do it." -- M.C. Escher, in a letter to his son Arthur, 12 February 1955
    http://www.ejectejecteject.com/
  10. #10
    Join Date
    May 2003
    Posts
    8
    Post
    You are right, Jaycephus!
    The idea with the bitmap-mask for the specular map is perfect. I will give it a try.
  11. #11
    Join Date
    May 2003
    Location
    Parker, Colorado
    Posts
    1
    Post
    I attempted to access the program specified, as I have the same problem, but I get a access forbidden error. Can anyone suggest where else I can go to get this plug-in for max 5.1
  12. #12
    Join Date
    May 2001
    Location
    vancouver
    Posts
    3,693
    Post
    brian im using this plugin above and it works fine.. email me at mazap1@msn if you have anymore problems.
  13. #13
    Join Date
    Apr 2001
    Location
    New Zealand
    Posts
    841
    Post
    Hey dudes,
    I've writen a ZBrush 2 Max tutorial on the bottom of my old ZLand site... just click in my signature below ... Upham's ZLand for Newbies ... It uses the Habware plugin.
    As for exporting out of Max back to ZBrush I can't recomend the Habware plugin. I'll write a tut for this also.... soon.
    Upham
    Upham's ZLand! ZBrush For Newbies!
    http://zbrush.cjb.net/
  14. #14
    Member User Gallery
    Join Date
    May 2002
    Posts
    92
    Post
    Hey guys. I'm having the same problem as the
    magician with my material not mapping correctly in max.I know its probably something really simple.I followed Upham's
    tut,(I thought to the letter)but its still
    not working.Should you use auv tiles or
    assign a mapping method(planar,spherical etc.)to the adaptive skin before you export?
    When in max you have to apply a uvw modifier
    to the obj...and then what?I'm pulling my
    hair out over here. Any help would be appreciated.Thanks,Murray
  15. #15
    Join Date
    Apr 2001
    Location
    New Zealand
    Posts
    841
    Post
    Hey Murray
    Sorry, Sorry ... My fault! I've got to change step twenty so it reads ... "Now turn off and then on - the "VIEW IN VIEWPORT button" (material editor), so it will refresh the bit-map on the model in Studio Max!
    Silly - me bad.
    Does this change things??
    Upham
Page 1 of 2 12 LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
