GRAFIK,
Try to work at a low level of SubD before you move up to the next
Post a front view if u can
Kevin
Thanks for the advice Kevin, I struggle with head models but I really want to learn how to make a decent one. I will start again from scratch and be more patient before increasing the SubD levels. Any more tips would be much appreciated. Cheers.
No worries GRAFIK!
Don't forget that you can always go up and down the SubD level whenever you work...
edited* Maybe you could go back to level 1-2 and then move ur points around by using a larger brush size...
