Is smooth the opposite of inflate? Seems that way.
pull on a 3d object and make it really pixolated
now chose smooth
now if its the opposite then, hold down your ALT key with inflate and drag on the pixolated mesh
the ALT key will change it to the opposite
since you said it was opposite then holding down your alt key would make it the same
now compare
they dont do the same
What’s the difference between nudge and move?
chose the Sphereinder3D and face the smooth part towards you
turn on the wireframe
now with intensity 100 move the middle top half and move back and forth a few times with std move
now below that with intensity 100 draw mode with nudge do the same below that and compare
If alt-inflate deflates, then why doesn’t z-sub in inflate mode deflate as well?
it does your not set to STD Mode
How are pinch and smooth different?
again turn on the wire frame with intenisty full blast and you can clearly see the differnts
