1. #1
    Senior Member Follow User Gallery
    Join Date
    Jun 2011
    Location
    Cape Town
    Posts
    148
    Default Q: layer system - layer count etc.
    Hi
    I want to dig a bit deeper into the layer system of zbrush, fairly limited but here goes:
    I naturally want to get the names/values etc. But the big thing is to get the value of how many active layers there are. I see that the window ID has a set number, and if you scroll down in the layer window that number is the first layer in the "active area"
    So Layer 0 would be 327, layer 1 would be 328 (window ID). If you scroll down if you have many layers, the layer that is at the top of the window for example layer 8 would also be 328.
    Is there a better way to track this, create a list etc.
    Thanks in advance.
  2. #2
    Moderator Follow User Gallery
    Join Date
    Jun 2004
    Location
    UK
    Posts
    11,310
    Default
    Here's a short script which will show you how to do it.
    Any questions, let me know.
    LayerNames.txt
  3. #3
    Join Date
    Jun 2011
    Location
    Cape Town
    Posts
    148
    Default
    Thanks Marcus for the speedy reply as usual
    I was fearing the scroll bar hack hahah dammit. I will go through it.. Zbrush nudge nudge change this
    Will get back to you, appreciate the txt file!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
