1. #16
    Default fbx
    one way is to use to the Zbrush fbx plugin or send the model to another program and scale it up
  2. #17
    Member Follow User Gallery
    Join Date
    Sep 2008
    Location
    Denmark
    Posts
    35
    Default Apply rig to model in TM
    Just played around with this plugin. Works fine. I created a model and a rig which I saved out. When done with the model, pose etc. I clicked "get model" knowing I would not be able to change it inside the plugin.
    Now: I want to use the rig on the model using "Transpose Master". Loaded in the rig and pasted in on - but it doesn't fit??
    Can this be done, please?
  3. #18
    Senior Member Follow User Gallery
    Join Date
    Dec 2007
    Posts
    1,010
    Default
    Considering buying this plugin as I have a few characters to build quickly. I was wondering, can it export the model, work on it, and then use Zbuilders posing tools to pose it?
  4. #19
    Default pose
    Yes you can pose in zbuilder
  5. #20
    Default
    Went ahead and bought it. Just straight in to using it for my first of 8 characters. Got a quick question. I have figured out (some) of the posing methods. But can't figure this one out. I have the hand and I want it to be rotated back (back of the hand rotated further back in the supplied image) and cant figure out how to do it other than selecting each of the knuckles and rotating them one at a time. If I click on the wrist it only rotates it round the way. Any ideas?
  6. #21
    Default doing a sculpt
    doing a sculpt of myself as Arnorld lol, started with zbuider and started to sculpt on it. I just cut in the eyes to make my own eyes.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  7. #22
    Default ZBuilder
    Just a quick test, converted in Cinema4D.
    An options for digging the mouth and the orbits of the eyes would be welcome, in order to insert the eyes and teeth.
    Also, the edge flow could be more circular around the eyes, mouth and chest.
    But it's a great plugin, anyway.
    B->
  8. #23
    Default
    So much potential. However, I felt that with muscles set to 0 the figure shouldn't be muscular at all, even as a full male. Also, set to full female, I felt the face was still way too manish, especially if young is set all the way to 1 and with young turned all the way up.
  9. #24
    Default sculpt still
    I love the plug in. People still need to sculpt still. The plug in can't do everything. I love the uvs, I can put the head on a different sub tool and make the uvs bigger for substance painter. Wish the eyes sockets were more back
  10. #25
    Default the viking's project
    I have been using zbuilder for a while, just playing around. Now I'm working on a viking.......... I have a suggestion , make the eye sockets hallow... I really like the tool
ID:	552104   Click image for larger version.
ID:	552105   Click image for larger version.
Name:	ZBrush ScreenGrab01.jpg
  11. #26
    Join Date
    Feb 2005
    Posts
    234
    Default custom face or body
    How do you make a custom face or body (imported from another model applied to zbuilder)?
    Will there be any documentation?
  12. #27
    New Member Follow User Gallery
    Join Date
    Oct 2006
    Posts
    7
    Default question about Zbuilder 2
    is it difficult or hard to convert the low poly models for games? and will there be a low poly version of Zbuilder?
  13. #28
    Join Date
    Apr 2005
    Location
    Germany
    Posts
    657
    Default Pose model just doesn't work, for me
    Hi, I bought this app recently and I just can't seem to get the Pose to work.
    Each time I try and pose, I followed your video online, I move the rig around and that's fine. The once I have done the pose I hit "done pose". It then says it wants to import mesh (which I didn't see Zbrush asking in your video). It says the topology of the mesh has changed press yes to transfer to high res mesh.
    If I hit yes it basically spend 3 minutes doing something and then just gives me the basic girl model, unposed and with all parameters gone including sub divisions.
    If I hit NO then basically this happens
    I really like the program but even when I edit mesh I lose all of my editing parameters so it is not much use at the moment.
    It works fine in your video, which I followed closely but it fails to work for me.
    Can anyone help?
  14. #29
    Join Date
    Nov 2010
    Location
    Sydney, Australia
    Posts
    150
    Default
    Marcus strikes again, what a legend.
  15. #30
    Default eye sockets
    I have one suggestion for the next version. If it's possible to get an option to make the eye sockets hollow
    Thank you
Page 2 of 3 FirstFirst 123 LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
