Does anyone know of Script to smooth a painted texture globally in ZBrush without holding {SHIFT}? Is there a brush that can be used to smooth? I could then use it to Color Fill Object with smoothing.
Why can’t you hold shift? If you want to smooth the vertex colors but not the geometry all you have to do is deselect “add” in the smooth brush but you probably knew this already…
Yeah, I just wanted an option to smooth all painted textures without manually painting it by hand. I could just do it in PS. I wish you could use the Smooth brush without holding shift.
Oh, you want to use the smooth brush without holding shift? Just select it as any other brush. This is for polypaint. You are talking about photoshop so I guess you are using texture images.
Smooth a texture would be like using a blur. And you can’t paint directly on textures unless you use projection master. And there you have 2.5 brushes like blur and smudge.
On the texture image you can use spotlight (smudge dial or brush)
