1. #76
    New Member Follow User Gallery
    Join Date
    Apr 2004
    Posts
    19
    Default
    Dear #AskZBrush, when will #Z4R8 be released?
  2. #77
    Join Date
    Dec 2014
    Posts
    7
    Default how to increase weld points distance?
    How to increase weld points distance?
    Why did the developers make it in strange units (100 mm % ?) ?
  3. #78
    Join Date
    Dec 2014
    Posts
    7
    Default
    how snap to point slice curve brush? It very usefull on low poly modeling.
    snap to vertex in preferences dosn`t work.
  4. #79
    Join Date
    Oct 2011
    Posts
    20
    Default
    hello, i have less than 10 hours inside of zbrush, i love it. my question is.
    i have 2 planes 3d with texture , so i can follow as reference for my "FACE SCULPT" then i try to move the camera, the planes are big and its easy to click on them when the camera is too close, and if i click on any of them (even if they are NOT ACTIVE SUBTOOLS) i cant move my camera,
    is there a way to move camera even if i'm clicking over a non active subtool that is on the background behind my sculpt?
    thanks in advance, i'm pretty sure theres a solution for that.
  5. #80
    Join Date
    Sep 2012
    Location
    California
    Posts
    42
    Default Array/Nanomesh question?
    I know that the insert mesh brush can be set to use a random insert mesh every time you use it. Is there any way to populate array/nanomeshes in similar fashion? Obvious example... convert IMM with multiple bricks to Insert Nanomesh brush then populate a single poly wall with a checkerboard pattern of random bricks then use the nanomesh setings to arrive at your brick wall result with all the rotate/offset etc options working across the random yet same group insert meshes. If there is no way to do that, would be a good addition in the organic yet procedural vein .
    "Art is a lie that tells the truth." ~Pablo Picasso
    Check out my deviantART account if you are so inclined: http://th3-gr3at-escap3.deviantart.com/
  6. #81
    Senior Member Follow User Gallery
    Join Date
    Dec 2007
    Posts
    402
    Default
    Was ZB 4.8 canceled?
  7. #82
    Join Date
    Nov 2009
    Posts
    182
    Default
    Is there a way to snap a curve to an edge? For example to snap a zipper to a coats edge.
  8. #83
    Join Date
    Jun 2005
    Posts
    20
    Default Transform Handle visuals
    I was wondering if there is a way to change the transpose handles visually so that I know when I am using move, scale, or rotate? This could be a color change or perhaps squares (move), Triangle (scale), and rotate (circles). like other 3d program widgets?
  9. #84
    Join Date
    Apr 2017
    Location
    Ireland
    Posts
    3
    Default Zbrushcore not maximizing
    Hi
    I am new to Zbrush. I have purchased Zbrushcore and all is good the only thing is when it open and is at mazimum screen size it does not cover the full screen there is a little on the left side and on the top but also on the top the top ui buttons seem to be a little missing. If I click out of max and free max it all is ok.
    When I got it first I think it was ok. Any help would be great to fix this.
    M
  10. #85
    Join Date
    Mar 2015
    Location
    England
    Age
    51
    Posts
    369
    Default screen size and ui
    Hey there
    i watched and learnt from the videos you post thanks for that,
    I want to know my screen is 1440x900 now i have seen a few ui that have 2 or 3 rows on each side and some at the bottom of the tools materials and such,when i do this i can only have one row,please tell me how to add more so i dont have to keep going in the menus,thankyou in advance..or is it dependant on screen size forgot to ask
    Be lucky,and if ya not lucky,dont get caught
    http://dolly40.deviantart.com/
  11. #86
    Join Date
    Dec 2007
    Posts
    402
    Default
    I would like to know if there have ever been any talks about collision detection. It's the one thing I really wish Zbrush would have because it's primarily a modeling app. Being able to conform objects to others in a more organic way (the Zbrush way) would be amazing. Like you move an object onto another with the transpose tool and it gives you different options for deformations. Would be helpful for hair strands, clothes, everything.
  12. #87
    Default Frequently causing unwanted problems
    English is not my first language. And Let me know if my question is not appropriate here.
    Sometimes I put the texture on the mesh and projection.
    Suddenly it stops and meshes are created.
    Why does this happen?
    Attached Thumbnails Attached Thumbnails Click image for larger version.
  13. #88
    Join Date
    Sep 2014
    Location
    Finland
    Posts
    11
    Default Panel loops
    How do you achieve panel loops like this? What is the easiest process?
  14. #89
    Join Date
    Apr 2004
    Location
    Zaragoza (Spain)
    Posts
    30
    Default
    Hi there;
    I don't have twitter but I guess it is fine to ask here (if not, please delete de message at will).
    Question: Is there a way to put the new gizmo to a desired mathematical place like the ZERO world coordinates?, I can't find any way to do that.
    Thank you in advance.
    _______________________________
    Visit my BLOG
  15. #90
    Default Ring enlargement or reduction
    Hi I am a jeweler student. I learn zbrush for jewelry. How to enlarge the ring of the ring. How can i adjust ring sizes
Page 6 of 7 FirstFirst ... 34567 LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
