I am experiencing a bizarre problem with the mirror and weld command. I have a model perfectly centered and trying to work on one side of the torso and do a simple mirror and weld the part to the other side. Strange thing is when I delete by symmetry, zbrush cuts and deletes the torso perfectly in half. And following that, when I mirror the half, it does the job as expected again but when I try to mirror and weld, it produces the mirrored part and sort of pushes it into the original one, making it a complete blob-like mess, can’t figure out why that is happening… Tried the uniform command under deformations before hand but it just made the torso humongous so that didn’t help.
If any of you guys have any idea as to what I might have been doing wrong, will very much appreciate your input.
Cheers.
