1. #1
    Senior Member Follow User Gallery
    Join Date
    Jun 2010
    Age
    33
    Posts
    437
    Question Fibermesh Export, then Import into ZBrush loses its info
    Hey guys,
    Is there a way of exporting fibermesh out and importing it back in ZBrush and still have the grooming brushes be functional? Currently, when it is imported back in it will get treated as a normal object which is somewhat expected.
    If there is a way, how can that be done? Is there any place ZBrush store fibermesh info which they can be retrieved even through ZScript so that when the fibermesh is imported, the grooming brushes can correctly work on it?
    I really hope there is a way!
    Thanks!
    Yasin Hasanian | CG Artist
    LinkedIn
    ZBC forum
    ArtStation
  2. #2
    Join Date
    Aug 2011
    Location
    Mebane, NC
    Posts
    4,194
    Default
    You can store your fiber settings so you can recreate your hair later, but once they leave as a mesh that's it.
  3. #3
    Join Date
    Jun 2010
    Age
    33
    Posts
    437
    Default
    Thanks for the response Doug, however, I'm not really wondering about storing Fibermesh creation settings, I'm wondering what makes fibermesh different inside ZBrush that the grooming brushes can be functional on them. This would hopefully allow me to still have those brushes functional even if I import a fibermesh into ZBrush.
    LinkedIn
    ZBC forum
    ArtStation
  4. #4
    Moderator Follow User Gallery
    Join Date
    Jun 2004
    Location
    UK
    Posts
    11,462
    Default
    I imagine that the fibers are tagged in some way so that ZBrush recognizes them. But there's no way to restore the tags that I know of.
  5. #5
    Join Date
    Jun 2010
    Age
    33
    Posts
    437
    Default
    Ah that's kinda depressing, I wrote a whole plugin to reduce fibers but then knowing they can't be treated as fibers made it all useless
    LinkedIn
    ZBC forum
    ArtStation
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
