Question: rename subtool? script execution issue
Hello everyone! Please can someone explain me…
  1. is there a way to rename subtool?
  2. when i trying to use “decimation plugin” (like [IPress, “Zplugin:Decimation Master:Pre-process current” or anything else] right after that my script immediatly stops execution. Is there a way to continue it or maybe start another one?
    Ex:
[IButton,“DoSomeThing”,
[IPress, “Zplugin:Decimation Master:Decimate Current”]
[MessageOK,“It’s Alive!!”] //Nope probably not
Thank you in advance for your help
The problem is Decimation Master is Separated Scripts and in Zbrush u can run only one Script at time.
So when your script trigger Decimation Master it stop working and Decimation Master script take controle.
Ok i got it, thank you. I just thought there might be some kind of tricky way
There are a couple hacky ways to rename subtools. The way I rename subtools is by, setting the SubD to 1 then moving it to the top of the stack and then setting the path with:
[ToolSetPath, Tool Index (zero based). If omited then uses the currently selected tool., New Path. Path extension (such as .ztl) will be omited.]
You could also save the file to a temp directory to rename the subtool but I find this to be much slower on dense meshes. Either way I “believe” the subtool has to be at the top of the stack.
Nyx 702, thank you sooo much! It almost drives me crazy.
Much appreciated for your help, guys
http://eat3d.com/forum/tips-tricks-and-free-videos/my-zbrush-plugin
Do not know exactly not it? Now backed exchange
