1. #1
    Member Follow User Gallery
    Join Date
    Oct 2011
    Location
    New York
    Posts
    87
    Default Is there any way to get decimation master to work in a macro or a script?
    Is there any way to get decimation master to work in a macro or a script? When I playback a macro with decimation master I get a file save dialogue and then an error message. Also does any one know why decimation is a two step process? Would there ever be a time when you would want to pre-process an object without then decimating?
    Thanks for any help,
    -Joe
  2. #2
  3. #3
    Moderator Follow User Gallery
    Join Date
    Jun 2004
    Location
    UK
    Posts
    11,462
    Default
    Quote Originally Posted by joe_lert View Post
    You can't run Decimation Master, or any plugin, from a script or macro because two zscripts/plugins/macros can't be active at the same time.
    Decimation Master pre-processes so that it has all the data necessary to efficiently decimate your model. You can then decimate at different levels without undoing the previous decimation or pre-processing again. This means the whole process is more efficient than pre-processing and decimating in one step.
  4. #4
    Default would be very nice to be able to make some macro's or scripts for polyreduction...
    the logic makes sense, the functionality is missing tho imho.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
