Hi!
I’ve been trying to expand/maximize any menu (for example the render menu) or docking it to the side tray, but I have not been able to.
I have been able to maximize a menu that IS already docked to the tray, but ZBrush crashes when I try the command [IMaximize, Render:, 1] when the render menu is NOT docked to the side tray.
The end goal is to expand a menu and scroll it down to an interface item of my choice. I have also been unsuccessful using
[IShow, Render:Bpr Ao] // I don’t get this command to work on any interface item.
[IPress, Render:] //Works with interface items like buttons, but does not seem to work on menus
[IClick,867,30] //Works with a menu that is docked (if I use other variable values). In this case i have omitted an interface item path, since I guess the menus are in the “root”. The XY mouse coordinates are supposed to “hit” the render menu, but might differ depending on interface layout.
I would love some help on this. I have been banging my head against this problem, which I thought would be easy to solve.
