1. #1
    Cool From a ZBrush model to a wood sculpture
    Hey Guys,
    I would like to share some information about a production process I have developed this year, together with a local wood carving company (3DWood). We already use this production pipeline daily now, because it has so many advantages; and ZBrush plays a major role! (how could it be otherwise )
    I'm going to explain the steps with the help of two models that are available on my website: www.ben-godi.com
    1. Digital Sculpting
    ZBrush allows me to create and sculpt the model entirely on the computer; from concept to final sculpture. I'm able to change things based on client's feedback quickly, with no need of making laborious changes on a clay model for instance.
    What I have to keep in mind is, that the outcome will be a physical object and in this case, an object made out of wood. As you already know for sure, wood consists of fibers that growth in a certain direction. Therefore it's necessary to avoid thin parts that go across that wood grain. They break easily.
    When I work with different subtools, I always make sure that the meshes are closed and watertight surfaces and intersecting with each other. You can do that, by starting with a ZBrush primitive for your basemesh and turn it into a dynamesh. A dynamesh will always force a closed surface by closing holes automatically.
    2. Preparing for 3D Printing
    When I'm done with sculpting, I make use of the "decimation master" plug-in and reduce the polycount. A super-highres mesh isn't necessary for printing. Most of the time I merge all subtool before I export the geometry as an STL file with the "3D Print Exporter" plug-in. I use Magics RP from Materialize to combine all shells to a single shell and to fix mesh errors, in case the model has any. Removing shells is necessary for giving your sculpture a wall thickness later on. You don't have to use an external application for merging shells. Merge all subtools to a single subtool in ZBrush and turn the whole thing into a higres dynamesh (with the project function enabled to keep your details). By doing that, you can get rid of the polygons at the inside of your model. In Magics RP I define a wall-thickness and perforate the sculpture, so the dispensable powder can be removed after printing.
    3. Prototype and Production printing
    For production on the pantograph (see point 4 below) you need to work on a reference model that is at least twice as big as the final wood figurine. That's necessary for transferring all the small details to the wood and makes it a lot easier to work with, because you must trace the surface by hand on the machine later on. But before I order the big printout for production, I go for a small version, ideally the size the final wood sculptures will be, to see how the model looks as a physical object. Whenever I feel something doesn't look right, I go back to ZBrush and try to fix it (composition, balance...)
    I normally use Shapeways (www.shapeways.com) for printing. They have Z-Corp printers for a printout in Sandstone (works great for all prototype models) and big laser sinter machines for printing a very strong nylon/plastic. That's exactly what I need for the pantograph.
    4. Production on the Pantograph (3d profiling machine)
    I fill the double sized plastic 3D printout with a special resin and mount it on a metal plate. Everything has to be assembled very strong to prevent it from bending or changing its position during tracing on the machine. The tracing itself isn't an automated process yet; you still have to do it by hand. And you have to be super careful. Oh boy, in a moment of carelessness you can ruin a whole row of figures! You start with some bigger milling heads for rough machining and switch to the smaller once for detailing. I use maple wood for my work. It doesn't change its color over the years and allow very fine details.
    5. Finishing and Refining
    The figures that come straight from the pantograph look great but aren't finished yet. It needs a lot of sandpaper work to smooth the surface. I add details with my set of small carving knifes and boost the once that disappear during milling. Finally I paint the parts I want to be painted and add a thin layer of wax that prevents the wood from getting dirty.
    6. The final product
    If you keep an eye on some production restrictions, (wood as a living material, the dimensions the pantograph allows, avoiding spots that are difficult to reach with the milling heads) the possibilities are endless!
    For more information, please feel free to visit:
    www.ben-godi.com
    www.selwy.com
    www.3dwood.com
    www.shapeways.com
    Kind regards,
    Selwy
  2. #2
    Senior Member User Gallery
    Join Date
    Sep 2004
    Location
    Gorzów Wlkp
    Age
    28
    Posts
    119
    Default
    sir you just destroyed the system, brilliant!
  3. #3
    Join Date
    Jan 2008
    Location
    Poland
    Posts
    604
    Default
    Haha!
    Very interesting! Can you explain the pont 4 more? How the 'carving' looks like?
    My Sketchbook - please visit and leave me some C&C to help me immprove myself
  4. #4
    Member User Gallery
    Join Date
    Feb 2008
    Location
    Norwich
    Age
    32
    Posts
    82
    Default
    Absolutely f***ing incredible!
  5. #5
    Join Date
    Jan 2004
    Location
    UK/Bulgaria
    Age
    39
    Posts
    1,155
    Default
    Beautiful sculptures.
  6. #6
    Join Date
    Nov 2007
    Location
    Canada
    Posts
    3,279
    Default
    WOW! This is absolutely stunning work.
  7. #7
    Join Date
    Feb 2002
    Location
    France
    Posts
    14,107
    Wink Trees don't say...
    ...thank you !
    Very cute sculptures!
    Is beautiful that please without concept! ( Me and maybe also E Kant)
    Pilou's Galerie Pilou's Tips Tuts Page
    Cameyo's ZPlace Art Surfing Albums
    Dedicaces Perpetual Challenges
  8. #8
    Join Date
    May 2012
    Posts
    130
    Default
    beautiful outstanding work. Nice and clean.
  9. #9
    Senior Member
    User Gallery
    Join Date
    Feb 2009
    Posts
    110
    Default
    Fantastic piece!
  10. #10
    Senior Member
    User Gallery
    Join Date
    Aug 2007
    Location
    São Paulo - Brazil
    Posts
    296
    Default
    Amazing idea and execution!
    Thanks for sharing the process!
    Best regards,
    Fábio Paiva - http://fabiopaivaart.com/
    Available for freelance
  11. #11
    New Member User Gallery
    Join Date
    Nov 2012
    Posts
    2
    Default
    very nice!
  12. #12
  13. #13
    Join Date
    May 2006
    Location
    LA
    Posts
    203
    Default
    I love this. I have been a carver (hence my forum name) for years. I have always wanted to output my zbrush work into wood. I don't have easy access to replicators. Man, it must be awesome to be able to hold a wood copy. Your work is great! Yet another process is pulled into the Zbrush fold.
  14. #14
    Join Date
    Aug 2007
    Posts
    1,127
    Default
    Excellent workmanship!
    "An artist never really finishes his work, he merely abandons it."
    Paul Valery
  15. #15
    Member
    User Gallery
    Join Date
    Sep 2011
    Location
    london englandd
    Posts
    78
    Default ;)
    yeah
    Portfolio
    marcovergantini.daportfolio.com
Page 1 of 6 1234 ... LastLast
Tags for this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
