This is my current ZBrush theme and little sneak peak on my latest project. Feel free to download this theme and my other configuration files bellow:
Theme
I have toned down colors to have much more subtle UI. In that way, I can concentrate much easier on the project. Current set of colors is also pretty much compatible with Creative Suites (PS6) - Dark theme as well. You can load this theme under Menu>Preferences>Icolors>Load UI colors.
Colors.zip (457 Bytes)
Macros
Regarding my macros, from ‘toggle’ macro I have found somewhere here on the forum, I have made a custom set of three for toggling between Clip brushes (Cycle Clip, Slice Curve), Mask Selections (Mask Rectangle, Mask Curve, MaskCircle, MaskPen) and Selections (Rectangle, Lasso). If you would like to use them just put them under your Zbrush folder. Default file path would be ‘C:\Program Files (x86)\Pixologic\ZBrush 4R4\ZStartup\Macros’. You could set up a custom key for each one under Menu>Macros by clicking on each one while holding Ctrl+Alt+LMB.
Macros.zip (7.44 KB)
Hotkeys
You can load this config under Menu>Preferences>Hotkeys>Load - button. Just open a file .txt to see my setup. Constantly used buttons are now mapped to the left side of keyboard so I can fire each tool - shelf just by left hand (Shelves: Alt+1, Alt+2, Alt+3, MRGB,RGB,M>Alt+Q, Alt-W, Alt+E etc.).
Hotkeys.zip (596 Bytes)
Config File - Custom Menus, Shelves etc. You can load this config under Menu>Preferences>Load UI - button.
CustomUI.zip (4.26 KB)
Feel free to comment, I will update this section with new stuff if you find it useful.Macros.zip (7.44 KB)Colors.zip (457 Bytes)CustomUI.zip (4.26 KB)Hotkeys.zip (596 Bytes)
