1. #1
    Senior Member Follow User Gallery
    Join Date
    Feb 2004
    Location
    USA on Planet Earth somewhere in the Universe
    Posts
    1,438
    Default multi obj importer is there a way for it to work with ZB4r4p2?
    SpaceMan's Space Book Journal On ZBrush
    http://www.zbrushcentral.com/showthr...rnal-On-ZBrush
    Wormholes were first introduced to the public over a century ago in a book written by an Oxford mathematician. Perhaps realizing that adults might frown on the idea of multiply connected spaces, he wrote the book under a pseudonym and wrote it for children. His name was Charles Dodgson, his pseudonym was Lewis Carroll, and the book was Through The Looking Glass. ***8212; Michio Kaku
    It's kind of fun to do the impossible...
    - Walt Disney
  2. #2
    Moderator Follow User Gallery
    Join Date
    Jun 2004
    Location
    UK
    Posts
    10,983
    Default
    If you simply want to import a bunch of OBJs (or ZTLs) as subtools then the SubTool Master MultiAppend function will do that.
  3. #3
    Join Date
    Feb 2004
    Location
    Posts
    1,438
    Default
    Thanks marcus that works great.
    How do I save each sub-tool as a single ztl file - I couldn't find that one on the Sub-Tool Master just export as obj - goz comp - goz bin - ,ma and .x3d.
    Is there a way to auto save each sub-tool as a single ztl file?
    - Walt Disney
  4. #4
    Join Date
    Jun 2004
    Location
    UK
    Posts
    10,983
    Default
    Quote Originally Posted by SpaceMan View Post
    You can't do it using SubTool Master because saving a ZTL which has subtools will always save all the subtools as well.
    You can try this zscript which is a quick adaptation of MultiAppend (you must have SubTool Master installed for it to work):
    1. Unzip the file and copy the MultiSaveZTL.zsc file to the ZBrush 4R4/ZScripts folder.
    2. Press the Load button in the Zscript palette and select the file. Press 'H' to get the button to show in the zscript window at the bottom of the UI.
    3. Pressing the button wil launch an Open File dialog. Select the OBJs you want by Shift+selecting or using Ctrl+A to select all files in a folder.
    4. All OBJs will be saved to the same folder as ZTLs.
    Download here: MultiSaveZTL.zip
    HTH,
  5. #5
    Join Date
    Feb 2004
    Location
    Posts
    1,438
    Default
    Marcus thanks very much - excellent
    This zscript with subtool master solves a couple of problems. One of which is backing up ztls as objs so they can be loaded in future vers of ZBrush. I started going through some of my old files created with zb 1.2 and zb 2.0 and these files will not open zb 3.5 throuh zb 4r4p2.
    Now with this zscript as I go along I can save out my ztls as objs and if the zb changes and won't open the ztl I can load the objs in and use the zscript to save back out as a ztl in the new zb ver.
    Again thank you very much for taking the time to create this zscript.
    - Walt Disney
  6. #6
    Join Date
    Jun 2004
    Location
    UK
    Posts
    10,983
    Default
    No problem, I'm glad you found it useful.
  7. #7
    Join Date
    Jun 2011
    Location
    Cape Town
    Posts
    140
    Default
    Hi Marcus
    Any chance I can have a look at the code you used to execute this?
    Thanks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
