1. #16
    Moderator User Gallery
    Join Date
    Jun 2004
    Location
    UK
    Posts
    7,679
    Default
    ZbrushFactory,
    You can do it like this. Note that [IModSet] is not always reliable; it is best to test the Mod and then simply click on the subtool to make it visible/invisible.
    This example runs through all the subtools and turns them off if necessary. (Note there is no error checking to see if a polymesh is selected, if there is more than one subtool, etc.) :
    Code:
    [IButton,TurnOffAllSubTools,"Loop through all subtools and turn them off",
      //this avoids an error if the top subtool is selected & hidden
      [If,[SubToolGetActiveIndex]==0,//if the top subtool is selected
         [SubToolSelect,1]//select the second subtool
      //loop through all subtools
      [Loop,[SubToolGetCount],
        [SubToolSelect,[Val,n]]//select the subtool by number
        [VarSet,subToolPath,[IGetTitle,Tool:Item Info]]//get subtool name
        [VarSet,subToolPath,[StrExtract,subToolPath,0,[StrLength,subToolPath]-2]]//trim off period
        [VarSet,subToolPath,[StrMerge,"Tool:Sub Tool:",subToolPath]]//set the path
        [If,([IModGet,#subToolPath]>=17),//check the mod
          [IClick,#subToolPath]//click to turn it off
    ,n]//end loop
  2. #17
    New Member User Gallery
    Join Date
    Apr 2004
    Location
    Poland / UK
    Posts
    4
    Default
    Thx Marcus. I solved the problem.
  3. #18
    Join Date
    Apr 2004
    Location
    Poland / UK
    Posts
    4
    Default
    If you don't mind Dragotron , I put one more question in your Thread.
    I don't want make a rubbish on the forum.
    Marcus maybe you have idea how to check if subtool is zsphere ?
    I have idea that I can check this by name, but what will happend when user will change name :/. This complicate all . There is some flag or marker that we can recognize zsphere from others sub tools like, for example, PolyMesh ?
  4. #19
    Join Date
    Jun 2004
    Location
    UK
    Posts
    7,679
    Default
    Quote Originally Posted by ZbrushFactory View Post
    You can test for the different ZTools like this:
    Code:
    [If,[IExists,Tool:SubTool:Append],//we have a 3D tool
        [If,[IExists,Tool:Geometry:SDiv],
          [If,[IExists,Tool:AdaptiveSkin:Make Adaptive Skin],
            [Note,"This is a ZSphere"]
          ,//else there's no Adaptive Skin option
            [Note,"This is a Polymesh"]
        ,//else there's no Geometry SDiv slider
          [Note,"This is a Parametric primitive"]
        ,//else there's no SubTool Append button
        [Note,"This is a 2.5D tool"]
  5. #20
    Join Date
    Apr 2004
    Location
    Poland / UK
    Posts
    4
    Default
    Cleverly. Thanks.
Page 2 of 2 FirstFirst 12
Posting Permissions
  • You may not post replies
  • You may not edit your posts
