1. #1
    New Member User Gallery
    Join Date
    Sep 2012
    Posts
    1
    Default mesh overlap problems
    OK, I'm new to the sculpting aspect of 3D modeling and have run into this problem multiple time and don't know how to solve it.
    While sculpting I manage to overlap area of the mesh (mainly because I am not paying attention). Using the deflate or smooth brush seems to make it worse.
    any suggestions other than start over?
    Thanks
    Riptyde.
  2. #2
    Senior Member User Gallery
    Join Date
    Aug 2011
    Location
    Mebane, NC
    Posts
    841
    Default
    Use the move topological or elastic to rough your shape, go to a lower division level.
  3. #3
    Join Date
    Jun 2011
    Posts
    787
    Default re
    Smooth, reduce, flatten, smooth reduce ..... if your in Symmetry mode .. Hit (9) on your keyboard, it will disappear half so you can work from the inside. The problem with Sculptris, the brush tool only works on the Normal ... not on backfaces, when the mesh crosses the backfaces start showing through. You can also Hide (H+Drag box) parts so you can work from inside .. hope this helps
Posting Permissions
  • You may not post replies
  • You may not edit your posts
