1. #1
    Default Maya 2013 -> GoZ importing problems
    So I have some objects that I've been trying to move into zbrush to do some sculpting on, and whenever I push the magic GoZ button i get an error that says:
    IMPORT ERROR
    Incorrect Face data detected.
    Operation canceled.
    OK
    After pushing OK, there is another dialogue box that says:
    Error encountered while importing a file
    I have spent a fair amount of time searching the internet for a solution to this problem but the only thing I can find is one thread located in the zbrushcentral archives. Which I am unable to access
    I have made other objects that import correctly using GoZ and I can import the defective meshes using an obj export/import just fine. I am really wanting to use GoZ for this transfer because I have creased edges on these mesh's and am honestly not proficient enough with zbrush to apply creased edges to them inside of the software.
    Any help would be appreciated.
  2. #2
    New Member Follow User Gallery
    Join Date
    Sep 2005
    Posts
    5
    Default
    Same is happening to me, new machine with maya 2012 hotfix 4, and zbrush 4 r4.
    Would love to be able to bring in a creased mesh. But I'm unable to import .ma files with or without GoZ. I was able to do so before with the same versions of maya and Zbrush on the old system. Confused of why it stopped working, I don't think is GOZ related for importing an individual .ma doesn't work. I've created a simple sphere in maya to import in Zbrush, same thing... Help!
    Thanks1
  3. #3
    Join Date
    Sep 2005
    Posts
    5
    Default
    OK at least for me the problem was solved once I deleted all my color sets. The mesh had 3 vertex color sets, which are independent of history. After that I was able to bring the mesh into Zbrush.
    I hope this helps!
    I saw another forum about maya 2013 that says it adds a -ch to the .ma file removing them seems to fix it temporarily...
    -Kjeld
  4. #4
    Join Date
    Feb 2012
    Posts
    4
    Default
    Quote Originally Posted by Mr.Kjeld View Post
    I hope this helps!
    -Kjeld
    This helped a great deal. I was having the same issue and had no idea I had vert color applied to the mesh and if it wasn't for this thread I wouldn't have thought to check
  5. #5
    Join Date
    Oct 2007
    Posts
    9
    Default
    excellent find. I just encountered the same error. Didn't find anything on vertex color, but I figured uv-data is also vertex data, and indeed; a second uv channel was the culprit. Removing that made a transfer to zbrush possible.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
