1. #1
    New Member User Gallery
    Join Date
    May 2007
    Posts
    21
    Default GoZ and Cinema 4D R13 problems.
    The first problem is one I've had from the start with GoZ. I have a scene created in C4D which consists of a couple of objects. Now when I go to send the objects to ZBrush I get the following error for some objects.
    "Object1" already exists in the current GoZBrush project. The object will be renamed "Cube"
    There is only one "Object1" in the scene so I don't know why it states this message.
    The other problem is that sometimes it doesn't send all of the objects over, and when it does, some of them are in the wrong place.
    Any ideas appreciated.
  2. #2
    Join Date
    Mar 2011
    Location
    TENNEESSE,USA
    Posts
    15
    Default Same problems
    Ive had the same problems since goz first came out ! Ive tried renaming to something thats not in the goz folder, and it still renames , it acts like it serches all your ztools for a duplicate,not just the goz folder, Just installed 4r4 today will try in it and see what happens. I have just been dealing with it ! Not enough of us c4d users !later DJ
  3. #3
    Join Date
    May 2007
    Posts
    21
    Default
    Glad I'm not the only one.
    I've tried renaming too, and I've also cleared the cache files from the ZBrush preferences menu but it doesn't help.
    It's the same for me with R4, and it appears to be an issue with the C4D side of things, as ZBrush will send to C4D without problems.
    I'm also baffled as to how some objects are imported in the wrong place when sent from C4D to ZBrush.
  4. #4
    Join Date
    Mar 2011
    Location
    TENNEESSE,USA
    Posts
    15
    Default seems ok now with 4r4 upgrade!
    It seems ok now in ver 4r4 that just came out, also I am using r13! am at djpixal1 at hotmail dot com if ya ever want to discuss issues , seems us c4d zbrush users are a small group!
  5. #5
    Join Date
    May 2007
    Posts
    21
    Default
    Ok mate, thanks for the update.
    I'm just coming back down to earth after reading up on Cinema4D 14 and the built in sculpting tools. Go and have a look at the Maxon site if you haven't already done so, it's impressive and I didn't expect that.
  6. #6
    Join Date
    Mar 2011
    Location
    TENNEESSE,USA
    Posts
    15
    Default r14
    R14 , am just catching up on r13 character stuff ! thanks will check it out!
  7. #7
    Join Date
    Aug 2012
    Posts
    1
    Question Same name when importing to Zbrush
    Quote Originally Posted by Dalmo View Post
    I've also the same problem with the same name into Zbrush.
    Why can't i start totally new with a renew model with a complete new name?
    Why is Zbrush remember things too much? So that i must initialize complete?
    I'm using 4r4 and also here C4Dr13 will gave this GoZ note that name already exists... pfff.
    Why not new name? And is there a sollution?
    Thank you all!
    Happy Zbrushing ,
    Danatomy
  8. #8
    Member User Gallery
    Join Date
    Sep 2005
    Location
    Palma de Mallorca (Spain)
    Age
    36
    Posts
    34
    Default c4d 12 too
    I use Zbrush 4r4 and Cinema 4d 12 and is happening to me too.
    It doesn´t matter if i rename all the objects in a clean scene to random and unsense words that is impossible that i have already in all the files of all my computer… GoZ averytime tells me that there is already another file called "aosdfygyh66a7s8a9s" and must rename. Renames but the mesh doesn´t appear in Zbrush, so is an unusable tool for me
  9. #9
    Member User Gallery
    Join Date
    Nov 2012
    Posts
    70
    Default
    Same problem here with 4R4 and C4D R13... It's going to get annoying trying to move objs around in the right place xD
Posting Permissions
  • You may not post replies
  • You may not edit your posts
