1. #256
    Lightbulb EyelashesCurve Brush v2
    Hi everybody!
    After some feedback about my EyeLashes brush i decided to release a second version with two brushes presets, and a better explanation of how can adjust some usefull parameters:
    Applying a Curve Brush from right to left (or viceversa) will determine if your eyelashes point up or down, showed below:
    To Adjust the size falloff:
    1) Go to the Stroke Menu.
    2) Turn on Size under the 'Curve Modifiers' Tab.
    3) Adjust the Curve Falloff to get the result you require
    To Adjust the amount of EyeLashes per stroke:
    2) Expand Curve Tab
    3) Adjust the CurveStep slider (Higher value for more spacing in between)
    If no Random EyeLashes needed:
    1) Go to the Brush Menu.
    2) Expand the Modifiers Tab.
    3) Set Variations slider to 1
    Optionally you can choose from 6 diferent EyeLashMeshes:
    3) Choose a mesh with the MultiMesh Slelect slider
    In most cases you will need to use the Transpose Tool and Move Brush to make adjustments. The Move Topological Brush is also recommended.
    Most cases autoMasking when using curve brush is activated. So is very usefull to use SplitUnasked Under Subtool palette
    I want to express my gratitude to BadKing for all the support. Thanks mate i´ll never forget your friendly help, BTW Great thread!
    You can download this brush here
    Or directly from this thread
    EyeLashes_FH_v2.zip
    Thanks for watching
    Franhazard
  2. #257
    Senior Member Follow User Gallery
    Join Date
    Feb 2010
    Location
    Barcelona/CATALONIA
    Posts
    907
    Default
    Good work, thanks for sharing
  3. #258
    Default
    Hi, thank you very much for your effort of sharing these, really helpful, for me at least. All the best!
  4. #259
    User Gallery
    Join Date
    Nov 2008
    Location
    Brazil
    Posts
    552
    Default
    Great add. Thanks for share it
  5. #260
    Join Date
    Feb 2006
    Location
    Tokyo
    Posts
    39
    Default Your awesome insert brushes!
    [QUOTE=aurick;964170]
    Hello Aurick! I love these insert meshes in these images... after searching the thread I can't see them. Are you hiding the awesomeness from us??
    Or am I simply blind?
    Thanks in advance!
  6. #261
    Join Date
    May 2009
    Location
    Montreal
    Age
    34
    Posts
    2,571
    Default
    These are amongst the standard IMM brushes in Z4 r5, select one of them in the brush palette then press M to choose one frome the category.
  7. #262
    Join Date
    Feb 2006
    Location
    Tokyo
    Posts
    39
    Default
    Quote Originally Posted by cherub_rock View Post
    doh! There they are. Thanks!
  8. #263
    Join Date
    Oct 2012
    Location
    Sydney, Australia
    Posts
    180
    Default
    Hi Guys... I've just uploaded another Freebie to my site... This IMM Bottle Brush Set is made up of 14 individual bottles, 2 Bottle Tops and a Straw.
    Here is the Link...
    http://www.badking.com.au/site/shop/...tle-brush-set/
    Enjoy
  9. #264
    Join Date
    Dec 2008
    Location
    Sigma - 957
    Posts
    118
    Default
    Thanks for sharing
    Cheers
  10. #265
    Join Date
    Jan 2010
    Posts
    33
    Default
    Many thanks
  11. #266
    Default
    thanks!
    tons of resources
  12. #267
    Join Date
    Feb 2010
    Location
    Barcelona/CATALONIA
    Posts
    907
    Default
    good job, thanks for sharing
  13. #268
    New Member Follow User Gallery
    Join Date
    Mar 2005
    Posts
    18
    Default
    Thanks for all for sharing
  14. #269
    Join Date
    Jan 2013
    Posts
    1
    Default Downloading insert multi-mesh brushes in OSX
    Download file. Open the Applications folder - Open the ZBrush 4R5 folder - Open Zbrushes folder - move the downloaded file into misc folder or make your own. Open Zbrush and start working!
  15. #270
Page 18 of 42 FirstFirst ... 91516171819202127 ... LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
