1. #1
    New Member User Gallery
    Join Date
    May 2012
    Posts
    2
    Default Using matcaps with texture maps
    Hello,
    How do you get zbrush matcap materials to show through once you've applied a texture map to your sculpt?
    Thanks,
    Chloe
  2. #2
    Moderator User Gallery
    Join Date
    Jun 2004
    Location
    UK
    Posts
    7,667
    Default
    The materials must be embedded into the texture map before they will display. If they aren't embedded then the map will only display the selected material, hiding the materials that you painted onto your model.
    If you are creating a new texture map from polypaint then you can include the materials by making sure the Draw>Mrgb button is switched on before pressing Tool>Texture Map>New From Polypaint.
    If you want to embed materials into an existing texture map then the simplest way is to install this little plugin:
    Materials to Texture Map plugin
    I hope this helps and let me know if you have any further questions.
  3. #3
    Join Date
    May 2012
    Posts
    2
    Default
    Thank you so much for your help Marcus!
Posting Permissions
  • You may not post replies
  • You may not edit your posts
