Hi Kostas,
Thanks you very much for the plugin. Until now I used the XGoZ which worked well for me
I'm testing it at the moment. As far your normal and displacement generations worked fine in a fast test I did.
But something is really strange (I think marciani has the same problem)...I'm
having strange behaviour concerning positioning:
I created in xsi from scratch a scene with 3 cubes. Then I send it to ZB. The cubes where imported into ZB but all have the same position. ( I've seen now that it's currently not supported...so sorry for that)
So after that I did a freeze al transform and sent it again to ZB....which gave me the result in the 3rd image...also strange.
Finally I tryed something different.
I exit ZB and XSI.
Then started XSI and opened the scenes with the 3 cubes (with freezed transforms and so on).
Then I hit the GoZbrush Button from the GoZ menu in Softimage... so that ZB now would start.
And finally that worked!
At the moment I'm quite confused why that was behaving so strange. I will keep on testing and see if I will have similar problems. I'm open to any ideas.
Thanks.
