This is a mixed example of uses for the FiberMesh utility. All the elements that you see apart from the flowers are simple 'accepted' FiberMesh states as subtools. Each one has been controlled mostly by using masks. The only element of these that has a FiberMesh UV applied is the leaves. Then the Flower was created using FiberMesh on the top of a sphere, with wide high coverage and minimal fibers with minimal gravity, this flower is then used as a MicroMesh replacement within the main Tree subtool set.
Pixologic ZBrush Blog
