1. #16
    Default
    Thanks Triar, I checked that path in the registry and the entry is already there, just as in your screen shot but GoUVLayout still doesn't work here. I deleted the incorrect one I had added earlier. Hopefully the newer version will fix this.
    Cheers,
    Brian
  2. #17
    New Member User Gallery
    Join Date
    May 2004
    Location
    xersones
    Posts
    4
    Default ZBrush4r2b
    Norman3D,
    i use ZBrush4r2b now, but in previous versions of Zbrush 4r2, this script does not work.
    Best regards
  3. #18
    Default
    ZB4R2b is the only version I've tried the script in here.
    Cheers,
    Brian
  4. #19
    Join Date
    May 2004
    Location
    xersones
    Posts
    4
    Default ZBrush 4R2/ZStartup\
    C:\Program Files (x86)\Pixologic\ZBrush 4R2\ZStartup\ZPlugs\GoUVLayout
    C:\Program Files (x86)\Pixologic/ZBrush 4R2\ZStartup\ZPlugs\GoUVLayout - in my ZB4R2b...
    Norman3d, muchas gracias !
    What do you think, whether period or comma in the system to influence this process? Or maybe Eset ESS 4, anti-virus and firewall?
    best regards,
    triar
  5. #20
    Senior Member User Gallery
    Join Date
    May 2005
    Location
    Copenhagen
    Age
    36
    Posts
    434
    Default
    hi,
    Is there and way to get it to work with ZR3?
    Best
    Daniel
  6. #21
    Join Date
    Sep 2012
    Posts
    1
    Default I would love to get this UVlayout Plugin working!!!
    Hey guys, Just tried out this plugin here on my 64 bit PC and i have the same issue. The script starts up in zbrush but doesnt open up the program. I dug down and it does appear to be creating the .obj in the GoUVlayout folder. So we just need to find a way to have Uvlayout open up. Any Ideas?
    -stephen
  7. #22
    Join Date
    Jul 2007
    Location
    Madrid, Spain
    Age
    24
    Posts
    387
    Default
    Oh wow, somehow missed all the replies! I'll hopefully have time to revisit the script in about a week or so. Sit tight!
  8. #23
    Join Date
    Dec 2004
    Location
    Los Angeles
    Posts
    29
    Default
    Just checking in to see if you have had time for a new build, I'm having the same problem, and would love to use this script.
    Thanks!
  9. #24
    Join Date
    Jul 2007
    Location
    Madrid, Spain
    Age
    24
    Posts
    387
    Default
    I believe I fixed the issues it was causing, it's now working on ZB4 r5!
    Just download it from the URL provided in the first post.
    This plugin is only for PC by the way!
    Let me know if you still issues!
  10. #25
    Member User Gallery
    Join Date
    Aug 2011
    Location
    Paysandú Uruguay
    Age
    35
    Posts
    52
    Default I think i´m lost...
    Quote Originally Posted by Norman3D View Post
    Mmmmm....where is the problem, i cant run it !
  11. #26
    Join Date
    Jul 2007
    Location
    Madrid, Spain
    Age
    24
    Posts
    387
    Default
    Alright, I just rewrote the whole script. I'm now using the new ZFileUtils, so you should see less DOS command windows popping up.
    I'm also saving the path of uvlayout to a txt file. If it's not found it will prompt you for the correct path of the uvlayout.exe file
    Give it a try!
Page 2 of 2 FirstFirst 12
Posting Permissions
  • You may not post replies
  • You may not edit your posts
