1. #31
    Senior Member Follow User Gallery
    Join Date
    Mar 2008
    Location
    Belgium
    Posts
    3,299
    Default
    Wow Marco, this is awesome, awesome stuff!!! Watching the creature come to life with the blendshapes is so cool (& extremely well sculpted) thanks for sharing so much of your workflow and the vids !
  2. #32
    Join Date
    May 2004
    Location
    Wellington, NZ
    Age
    35
    Posts
    1,660
    Default
  3. #33
    Join Date
    May 2004
    Location
    Wellington, NZ
    Age
    35
    Posts
    1,660
    Default
    hey guys thanks so much!
    Geert, I'm a big fan of your work, thank you!
    I'm holding on the rendered video...sorry I got a bit busy these days... I really wanna finish this
  4. #34
    New Member Follow User Gallery
    Join Date
    Sep 2011
    Posts
    23
    Default
    Very impressive and inspiring work, Marco... thanks very much for sharing!
  5. #35
    Join Date
    May 2004
    Location
    Wellington, NZ
    Age
    35
    Posts
    1,660
    Default
    thank you for your kind comment
  6. #36
    Join Date
    Aug 2003
    Location
    Budapest, Hungary
    Posts
    106
    Default
    Hello, I have a question about how you generate the displacement maps.
    In my experience the maps will only work reliably if I store a morph target of the basemesh immediately after importing it into Zbrush and before subdividing it. That's because of how the level 1 basemesh gets shrinked right after you press Divide.
    I will have to recall this morph target after the sculpting and before generating the maps. With any other approach, the resulting map will create artifacts, bad displacements etc. at rendering time.
    This meant that when I tried to create displacements on top of blendshapes, I had to do a lot of trickery with wrap deformers in Maya to create a version of the basemesh that I was then able to use for generating the displacements.
    So, what do you do to generate your maps? I see in the video that you subdivide the shapes, do you just switch to level 1 and generat your maps? This should create bad displacement maps, too... or do you have some trick for that?
  7. #37
    Join Date
    May 2004
    Location
    Wellington, NZ
    Age
    35
    Posts
    1,660
    Default
    hi LY, the method is reallly simple actually. What I found to get me the best results, was always to use the mesh that I sculpted on, no morph targets. I know that when you subdivide the mesh shrinks. That's the same that would happen if you would render the very same mesh as a subd in maya. In few words if you are a maya user and you press 3 to smooth the model in maya, that's the same thing zbrush would do when you subdivide.
    Since you are sculpting on this mesh, you are also changing the orientation of the normals of the base mesh from where you will bake your displacement map. That means that you have to apply the displacement map to the same base mesh that you use to bake your map to get the same result you have at your higher subdivision. You'd get the best result is by exporting your sculpted base mesh to maya; apply the displacement map that you baked in zbrush (without switching the morph target) and render. A good test you could do is to use GoZ to pass both mesh and map to maya and let GoZ to set the shader for you. You'll see that you'll find yourself working with the sculpted mesh from zbrush and the displacement map generated from that same mesh. Hope this helps.
  8. #38
    Join Date
    Aug 2003
    Location
    Budapest, Hungary
    Posts
    106
    Default
    That is not true in our experiences, we did extensive testing back in 2004 when we started to use Zbrush 2.
    I've even exchanged some emails with the Pixologic staff and it was their recommendation to use the morph target method.
    This is an image I've made back then:
    Left one is the geometry straight out of Zbrush, the other two were using displacements generated with either the standard level 1 basemesh, or the level 1 basemesh + the Cage button.
    I think the artifacting is obvious; it was a relatively low poly model so the problems were more extreme. We've had a lot of problem with sword edges and tips too, just look at this guy's teeth to see what we had going on with the weapons.
    But it's the same with anything else. Just try it with a simple plane, the border edges are shrinked in Zbrush and stay where they should in Maya.
    Also, Mudbox can work in the standard way, without ruining the level 1 basemesh, so it's clearly something specific to Zbrush and has nothing to do with how you subdivide in Maya.
  9. #39
    Join Date
    May 2004
    Location
    Wellington, NZ
    Age
    35
    Posts
    1,660
    Default
    Yeah I remember I used to have this kind of issues back then when using 16 or 8 bit maps. But now when I bake my 32bit maps out of the Multi Map Exporter I get the best results just by using the sculpted mesh.
    Something to be said is that I never use a mesh that is too low even if I believe that with a 32bit map you're still gonna be pretty close to what you sculpted.
    Are you using 32 bit maps? That was a really cool model by the way
  10. #40
    Join Date
    May 2004
    Location
    Wellington, NZ
    Age
    35
    Posts
    1,660
    Default
    Another thing. For props and hard surface models I still use the morph target for the reason I said before, the normal orientation. In that case I want the map to be baked out of the original mesh. But that's because I use ZBrush on hard surface models only for the high frequency details. The thing is that ZBrush doesn't bake vector displacement maps. So you have to make sure that your details are being displaced along the normals. That's another reason why you get that crazy pinch in the throat and artifacts.
    For organic models I found that the sculpted is the best geometry to be used, because you do sculpt more than just high frequency details and you want to make sure that the volumes (so the normals direction) you have in the highest subdivision are more or less reflected in your base mesh or when you render it will be required too much effort to reach what you had in zbrush.
  11. #41
    Join Date
    Feb 2012
    Posts
    2
    Default
    This is very good
    Superb ~
Page 3 of 3 FirstFirst 123
Posting Permissions
  • You may not post replies
  • You may not edit your posts
