1. #91
    Senior Member User Gallery
    Join Date
    Jul 2011
    Posts
    296
    Default
    I'm just playing around, not trying to be accurate, more like a caricature. Practicing on imagination and speed. I guess I need to keep working on it.
  2. #92
    Join Date
    Jul 2011
    Posts
    296
    Default manikin
    I created this manikin to help me figure out poses and also help me with foreshortening when I draw . ( foreshortening - A technique for creating the appearance that the object of a drawing is extending into space by shortening the lines with which that object is drawn.)
    Made it in Zbrus, rigged it in blender. I do like the rigging in z brush but wasn't sure how to rig multiple parts.
    Got the idea from the book, Andrew-Loomis-figure-drawing-for-all-its-worth. l like His manikin design.
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	295000   Click image for larger version.
ID:	295005   Click image for larger version.
ID:	294999   Click image for larger version.
  3. #93
    Join Date
    Aug 2002
    Location
    New Zealand
    Posts
    776
    Default
    Quote Originally Posted by nicksc View Post
    That is a nice mannequin. In ZB you could also try replacing the connector meshes of the existing mannequin with your own, or make your own mannequin from scratch using your meshes (though they might need to be optimised for poly count first). See here for how http://www.pixologic.com/docs/index....fferent_meshes
  4. #94
    Join Date
    Jul 2011
    Posts
    296
    Default Prey creature
    empty
  5. #95
    Join Date
    Jul 2011
    Posts
    296
    Default Predator creature
    empty
  6. #96
    Join Date
    Jun 2011
    Posts
    773
    Default
    Very Nice !!
  7. #97
    Join Date
    Jul 2011
    Posts
    296
    Default
    Thanks, justadeletedguy
  8. #98
    New Member User Gallery
    Join Date
    Mar 2012
    Posts
    6
    Default
    very nice sculpt
  9. #99
    Join Date
    Jul 2011
    Posts
    296
    Default
    Thanks, vineet_14
  10. #100
    Join Date
    Jul 2011
    Posts
    296
    Default Critique this sculpt
    Hi everybody. Working on a project that could bring some great opportunity for me. So I would really appreciate if everyone would critique this sculpt.
    Thanks.
ID:	347736   Click image for larger version.
ID:	347735   Click image for larger version.
ID:	347734   Click image for larger version.
ID:	347733   Click image for larger version.
  11. #101
    Senior Member
    User Gallery
    Join Date
    Jul 2009
    Location
    Athinai
    Age
    55
    Posts
    2,476
    Default
    I already commented it on the other forum.
    Just wondering, did you use sculptris for this? It looks like. At least at some basic point.
    GoZ links the two apps well, but IMO, pixologic should bring the whole Sc code into zbrush. Bad from a freeapp perspective but at least, we could see some important acceleration on performance.
    Dynamesh is good for sketching, but not that good. We need density in some certain areas, we can go up to million faces under dynamesh but this doesn't make things easier. A decimation in messed up areas is always the best solution to start over. Decimating the whole mesh isn't a good solution at all.
  12. #102
    Join Date
    Jul 2011
    Posts
    296
    Default made with sculpturis
    Yes it was made with sculpturis. Saw your work in blender, awesome!!! You need to create a sight like the blenderguru.com It would be a big help to all of us if you made video tuts for blender. We need people like you. Just think about it.
  13. #103
    Member User Gallery
    Join Date
    Jan 2006
    Posts
    63
    Default
    Very nice as usual.
    The only thing that doesn't convince me completely is the way you simplified the hair in some areas, it seems a little inconsistent given the attention to realism you gave to the cloth, the flower and the lips.
    Other than that I have nothing to say, you clearly know what you're doing.
    Just out of curiosity, in some areas the hair seem to be part of the body. Did you fused two objects with a boolean in another software or it's just a single object sculpted out from a primitive?
    I'd also like to see some tutorial from Michalis, I really like his style and the quality of his renders.
  14. #104
    Join Date
    Jul 2011
    Posts
    296
    Default
    hi2all do you have any examples of hair that could help. I fell the same way. or should I try to make it as real as I can. Yes I did combined parts, made it in sculptris and dinamesh it in zbrush.
  15. #105
    Member User Gallery
    Join Date
    Jan 2006
    Posts
    63
    Default
    Of course it depends on how you feel about it, but I think that you don't need to go overboard either.
    I like the way the hair separates behind the left ear, a little less the forward strands and the central separation that gives a "symmetrical" feel, I don't know how to put it correctly, I hope you get what I mean.
    You added some fine details on some areas leaving other with an unfinished feel, which in my opinion works quite well.
    I think you could use a similar approach to maintain consistency with the style you used till now, giving more crispness in the separation between big strands of hair to better suggest movement and making it less like a "melting" feel.
    As for the examples, as usual Philippe Faraut is a good reference
    http://philippefaraut.com/portrait.html
    Seb Zar is also quite interesting
    http://sebzar.com/page/2/
Page 7 of 8 FirstFirst ... 45678 LastLast
Posting Permissions
  • You may not post replies
  • You may not edit your posts
